Old 08-01-2005, 03:18 PM   #1
Sonia's Avatar
2006 34' Classic S/O
1992 25' Airstream 250
anywhere , New Jersey
The awful window locks on the Classics..
We have a 2005 30' Classic and some of the windows are so hard to lock. I am talking about the little silver things that you "push" down to lock the windows.
In the bedroom for the emergency exit, the ones we have are colored red and they are some easy to open and close.
Is there someting that I can do to the locks, to close them without killing my hands?
Sonia
Sonia is offline   Reply With Quote
Old 08-01-2005, 03:30 PM   #2
Aluminut
Silvertwinkie's Avatar
2004 25' Safari
. , Illinois
Yup! Trade me for my Safari windows!
Old 08-01-2005, 03:39 PM   #3
Sonia's Avatar
No thanks. We had the 2004 Safari Bambi. The windows didn't provide much air. I like the windows in the Classic but want an easy lock option. I am sure there is a fix, a spray or something to make it easier....
Sonia
Old 08-01-2005, 04:22 PM   #4
Pahaska's Avatar
2014 Interstate Ext. Coach
Hays County , Texas
You can open a window; go around on the outside; and adjust the nuts on the threaded rod outward slightly so that there is less pressure pulling the window inward.
I haven't done this for some time, but if I remember rightly, there is a double not so that it takes two wrenches to make the adjustment. Hold the inner nut, loosen the outer nut a turn, loosen the inner nut a turn, and then snug down the outer nut again.
It will not require a lot of adjustment, just enough that the window is not pulled inward against the seals quite so hard.
John W. Irwin
WBCCI #9632
Old 08-01-2005, 05:41 PM   #5
Kistler's Avatar
2002 25' Classic
Oro Valley , Arizona
Pahaska told me long ago how to make those adjustments. IF you put too much pressure on the bottoms of the windows (where the latches are) you can get a gap at the top.... I learned this the hard way/wet way in LA last spring. Just get them snug.
Kistler & Brenda
2002 Classic 25'
2003 Expedition EB 5.4L, AWD, AdvanceTrac Class IV hitch pkg. Reese dual cam/Prodigy
Kistler is offline   Reply With Quote
Old 08-01-2005, 06:56 PM   #6
Tinsel Loaf's Avatar
I put silicone on the gaskets so they won't stick. You have to clean the glass really well where the seal presses before you silicone the rubber gasket.
Tinsel Loaf is offline   Reply With Quote
Old 08-01-2005, 10:38 PM   #7
Cartoon Character
Porky Pig's Avatar
2004 34' Classic
On The Road , U.S.A.
Sonia ...
When the windows are open ... go outside and spray the threads of the locks with some silicone spray ... then go back inside and work the levers back and forth a few times. You'll feel the difference.
Porky
TrailerGypsies.com
WBCCI #3405 — Escapees #80360
I live the life I love and I love the life I live.
-- Willie Dixon
Porky Pig is offline   Reply With Quote
Old 08-02-2005, 05:51 AM   #8
wheel interested's Avatar
2007 23' International CCD
Lapeer , Michigan
Porky's right
leave it to a pig to tell you to get greased. Service tech used wd40 on mine and said I should never be without it. Made a HUGE difference, I was surprised.
Originally Posted by Porky Pig
Sonia ...
Caroljb
photography
wheel interested is offline   Reply With Quote
Old 08-02-2005, 06:07 AM   #9
Aluminut
2004 25' Safari
. , Illinois
Sonia
Had to give it a shot.
Old 08-02-2005, 07:55 AM   #10
jcanavera's Avatar
2004 30' Classic Slideout
Fenton , Missouri
Images: 143
Sonia
You can try the lube that Porky noted. If that doesn't help then the advice from Pahaska is the next thing you need to do. I have two tight windows on my Classic which need adjustment since they are knuckle busters in closing, just like yours. In my case I know that lube isn't the answer since the latch itself is free and easy to move with the window open. I'll be doing that adjustment this weekend.
Jack
Jack Canavera
STL Mo.
AIR #56
Old 08-02-2005, 09:05 AM   #11
Sonia's Avatar
Thanks to all the responses. I will try some of the suggestions this weekend.
Sonia
Old 08-02-2005, 11:56 AM   #12
rluhr's Avatar
1968 17' Caravel
2005 30' Safari
Somewhere , roaming America
Instead of silicone spray or WD-40, I used a Du Pont teflon-based liquid lubricant (Home Depot, $4 or so). It doesn't attract dirt and it probably will last longer than WD-40. The latches on my 77 Argosy were so rusty they barely moved but after a quick squirt of this stuff they all work like new.
Former full-timer | AIRSTREAM LIFE magazine | Tour of America (old blog) | Man In The Maze (current blog)
rluhr is offline   Reply With Quote
Old 08-02-2005, 02:19 PM   #13
Cartoon Character
Porky Pig's Avatar
2004 34' Classic
Actually .. I went and checked ... I ran out of silicone spray so I picked up a can of SuperLube Multi-Purpose Synthetic Lubricant with Syncolon® while visiting a marine hardware store in Anacortes, WA.
The can states the product is good for anything that slides, swivels, rolls or squeaks. And is authorized for use in federally inspected meat and poultry plants.
Porky
TrailerGypsies.com
-- Willie Dixon
Old 08-02-2005, 06:40 PM   #14
Synthetic Lubricant with Syncolon? What do you think Syncolon is made from.....
Window latch dilemma maxandgeorgia Windows & Screens 5 05-18-2018 10:35 AM
replacing compartment locks Dave Cole Exterior Storage Compartments & Access Doors 3 08-14-2008 07:34 PM
1974 Excella front window docu post john hd 1973-1974 Excella 500 22 08-06-2004 01:53 PM
Front Wing Window Repair Charles D. Bennett Windows & Screens 0 08-10-2002 06:04 PM
Window Frame Removal 64GT Windows & Screens 4 04-09-2002 12:40 PM
