Old 03-19-2015, 12:46 AM   #1
1985 27' Sovereign
Jonestown , Texas
Stripping window frames to repaint
Any advice on what to or not to use to strip the window frames? Some are in ok shape but the kitchen window at the very least is pealing.
Texas Gal 61 is offline   Reply With Quote
Old 03-19-2015, 08:29 AM   #2
Belegedhel's Avatar
1973 21' Globetrotter
Houston , Texas
It depends on what your frames are made of. Are you talking about the frames in which the screens are mounted (they were made of aluminum in the 70's), or the molded plastic "frames" that surround just a few of the windows? If the frame is made of aluminum, and you intend to replace the screen anyway, then a typical paint stripper like "Citrustrip" will work just fine. If you are stripping paint off of plastic, you will have to be very cautious, as many of the strippers available at the big box store will eat plastic.
good luck!
1959 Globe Trotter - want to repaint Red numbers on front. Kim Cannon Clearcoat, Exterior Paint & Trim 3 01-25-2008 02:18 PM
repaint 405billc Clearcoat, Exterior Paint & Trim 4 04-09-2007 07:54 AM
Logo repair and repaint gparker Clearcoat, Exterior Paint & Trim 4 09-26-2006 09:20 AM
vinyl repaint ted368 Upholstery, Blinds, Walls & Interior Finishes 4 05-15-2006 09:53 AM
? repaint the Argosy 77 R GO C MH Clearcoat, Exterior Paint & Trim 7 03-20-2004 06:47 AM
