Old 02-08-2014, 08:29 PM   #1
thinktankair's Avatar
1961 16' Bambi
grass valley , California
Strange Window Leak
I have two similar leaks that are causing water to leak on the floor. The leaks are at the back window and vent of my 1961 Bambi. The strange thing about the leaks are they are not coming from the outside sills, but inside. I have posted pictures. The outside sills are dry, but the inside sills are leaking horribly. I hope someone has experienced this before. Take out the window and reseal with Vulkum? Reseal some other way? The wierd sill leak is at the top of the window (see drips). Thank you!
Name:	water on sill of back upper window.jpg
ID:	205199   Click image for larger version
Name:	bottom door with water on sill.jpg
thinktankair is offline   Reply With Quote
Old 02-08-2014, 09:52 PM   #2
Becky B.'s Avatar
1964 17' Bambi II
Schererville , Indiana
It's a possibility that the leak is running from above the window (the seams or vents for example) and running between the skins and exiting inside the window. It can even be something as random as a rivet that's leaking. I've found the best way to find a leak is to use a hose & work your way up from below, and go up. If you start at the top, you have no idea if the leak is below it (I know, it sounds confusing, but if you try it you'll understand what I'm talking about) If your trailer is a '61, it wouldn't be a bad idea to go over the entire trailer and reseal it. There are probably a lot of leaks you don't know about & can prevent further damage if you're pro-active. Good luck!
Becky
1964 Bambi II
1988 Avion 32S
Becky B. is offline   Reply With Quote
Old 02-08-2014, 10:11 PM   #3
1974 Argosy 20
Kooskia , Idaho
Is it possible it is condensation, with it coming from the inside moisture condensing on a colder window or frame surface? Just a possibility to consider.
Old 02-09-2014, 03:50 AM   #4
1961 16' Bambi
Thank you so much for the replies! I thought condensation too, but the leaks stopped when I put a cover on the back of the bambi. So, I have check for lose rivets and I like the house idea! How do I resell seams without popping the rivets?
Old 02-09-2014, 05:15 AM   #5
RM66caravel's Avatar
1966 17' Caravel
Newport , North Carolina
Seam sealing is a well covered topic here and it seems that the most important thing that you need is patients.
Cliff
Gotta get busy! Have a great day! Now where did I put those revits?
RM66caravel is offline   Reply With Quote
Old 02-09-2014, 06:19 AM   #6
samb's Avatar
1961 22' Safari
Union , Oregon
Images: 11
I had similar leaks in my '61 Safari. I sealed the seams on the end caps and that stopped the leaks.
Sam
samb is offline   Reply With Quote
Old 02-09-2014, 06:36 AM   #7
Becky B.'s Avatar
1964 17' Bambi II
Use the "search" feature on the forum. Enter "sealing leaks" in the google search line. You will come up with hundreds of threads on the subject. I prefer Tempro for seams, and I have used par bond around rivets. I just started doing all the rivets on my Bambi II with captain trolley. All of these products are sold at Vintage Trailer Supply.
Becky
1964 Bambi II
1988 Avion 32S
Old 02-17-2014, 07:57 AM   #8
1961 16' Bambi
I sealed the seems with products and advice from vintage trailer supply. No leaks! Thsnksgiving everyone!
Old 02-17-2014, 06:54 PM   #9
Becky B.'s Avatar
1964 17' Bambi II
YAAAY!!! It's always great to hear that someone succeeded!! Keep us updated on your new baby!
Becky
1964 Bambi II
1988 Avion 32S
Should check valve leak a little? KYAirstream Plumbing - Systems & Fixtures 7 11-04-2012 10:09 AM
Gotta a small leak...FB pana Window THEPILL 2006 - 2010 International 5 01-02-2012 07:35 PM
2010 25' FB window leak. THEPILL Leaks - Weatherstrips, Gaskets, Caulks & Sealants 14 06-03-2011 07:21 PM
Rear window leak fixed! Really? I think so. 1964 GlobeTrottin 1960 - 1964 Globetrotter 0 04-30-2011 05:42 AM
Front window leak fix? BarnacleBill Flat-Front (Cutter, Clipper, XC, XL & Skydeck) Motorhomes 7 01-18-2011 05:04 PM
