Old 01-21-2014, 08:52 AM   #1
Alphonse's Avatar
2010 28' Flying Cloud
Lower Alabama , USA
Storm windows for the screen door
We wanted to add storm windows to our screen door so we could leave the main cabin door open in cool or hot weather and also lets us enjoy the feeling of the Twinkie being more open. Of course this avoids slamming the tight fitting cabin door when going in and out so much as well. Our friend Roadtoaster had already done this and I followed his trail and advice on the installation. I got this done about a year ago and thought I would post it here since another friend recently inquired as to what to buy and the layout.
Here's our layout:
Used acrylic sheet attached with 6 clips on the top and bottom sections respectively. I found the thin acrylic very flexible and it had a curvature in it from the store which I used to my advantage to fit the curvature of the screen door.
Here's what I bought:
- 12 clips from Lowes
- #8 - 1/2" long stainless steel sheet metal screws from Lowes
- One sheet of 0.093" thick acrylic 2' x 4' from Home Depot
The photo is showing a pack of the clips laying on top of the plastic. The photo is a bit confusing since both are laying on a table saw (you see the miter gauge slot in the photo).
The clips come with the machine thread screws which are #8 by 32NC threads. However I used #8 stainless steel self tapping sheet metal screws in lieu of the machine screws to avoid drilling and tapping 12 holes in thin aluminum sheet metal. The factory door frame is made using box sections so you only penetrate the front side of it when mounting the clips. This makes it hard to tap. Therefore the length of the sheet metal screws is also important so they don't bottom out on the back side.
I cut the acrylic sheet to size in the table saw. I radiused the top section's corners with a band saw fairly close and then sanded them to fit. By the way, I found a paint can that matched the top corner radius and used that as a guide to mark the cut. I sanded the radius of the top section and the sharp corners as well. The sanding is quite easy. Fair warning - you take a chance of cracking the acrylic sheet on the table saw and/or band saw since it is brittle by nature. I have learned this the hard way many times over the years.
Here are two plastic polishes I use. You may not need them but I dropped one panel and scratched it during the fitting process but was able to polish the scratch out. That is a positive of acrylic in that you can polish it and it doesn't yellow with age. By the way, I polish the window guards on the Airstream with the Plexus, it is really good stuff. I also use it on our cars, motorcycles, boats, and such. (Tip: buy it at Amazon, it is available at motorcycle shops but at a 50% premium.)
Hope this helps others avoid running to and fro hunting supplies and hardware like I did. The acrylic sheet I bought was from Home Depot because what Lowes had was too thin and I didn't want to make it out of the thicker material they also had due to the added weight to the light weight screen door. It gets enough abuse already!
Thanks to Roadtoaster for sharing the concept and his install with me at the Canopener in 2013. I like to replicate something that has been trialed and proven! He has a couple of other ideas that are in my work/modification plan as well but don't tell him cause he'll want high dollar bourbon in trade.
Alan
"If you must choose between two evils, pick the one you never tried before!"
Air #64439
Southeastern Camping Unit WBCCI #5033
TAC AL-8
2019 Canopenian
Alphonse is offline   Reply With Quote
Old 01-21-2014, 11:30 AM   #2
Skatiero's Avatar
1986 32' Excella
Canton , Georgia
This is a great idea! Thanks!!!
Skatiero is offline   Reply With Quote
Old 01-21-2014, 12:34 PM   #3
Foiled Again's Avatar
2012 25' FB Eddie Bauer
Virginia Beach , Virginia
Nice reminder!
acrylic - basic thing to know is that ammonia (Windex or any ammonia based window cleaner) is one of the two major causes of "haze." Your headlamp covers look like crap after 5 years because of sunlight and ammonia from washing the car and from everyone's windshield washer fluid. Driving in heavy traffic in the rain - everyone is using their washers as well as their wipers.
So your recommendations for cleaning the acrylic with a special product is excellent. Not a waste of money at all. As you noted it's great for the stone guards too!
Another source for acrylic at lower prices - sign shops and shops that make displays for stores. They have lots of scrap... and it wouldn't be unusual to find a couple of pieces big enough for a storm door. I even know a business that does nothing but replacement screens and storm doors for apartment complexes... I'd bet that would be a good place to look too.
Paula
Old 01-24-2014, 09:21 PM   #4
Alphonse's Avatar
Lower Alabama , USA
Correction - the SS sheet metal screws are #10 not #8.
Alan
Air #64439
TAC AL-8
2019 Canopenian
Old 01-24-2014, 10:14 PM   #5
1974 Argosy 20
Kooskia , Idaho
It is a good looking job and I plan to do something similar to my new 20' FC. What I did the second day I owned it was to remove the ugly (in my opinion) aluminum screen guards from the top and bottom panels inside. Unless you have dogs or little kids around I can see no value added by them and they block light and air when you have the door open and want ventilation.
Old 01-25-2014, 06:56 PM   #6
Alumitater's Avatar
2007 25' Safari
Spanish Fort , Alabama
screen door panels
Being a close neighbor and buddy (cooking, drinking and otherwise) with the fellow who started this thread, I plied him with strong drink to help me make the panels for my screen door. I installed them today. It is a great idea (thank you Roadtoaster) and as Brother Al says the best modification you can make for under $50. I can imagine one would find them handy for enjoying light without trying to heat or cool the entire campground. Thanks fellows!
Tom and Robin
2007 Safari 25' FB Twin
"If you have to go through a minefield....follow somebody"
Alumitater is offline   Reply With Quote
Old 01-25-2014, 07:35 PM   #7
Skatiero's Avatar
1986 32' Excella
Canton , Georgia
Looks wonderful!
Old 01-25-2014, 07:37 PM   #8
Skatiero's Avatar
1986 32' Excella
Canton , Georgia
Alumitater, could you please show pictures of the inside? Thanks!
Old 01-26-2014, 12:48 PM   #9
Alphonse's Avatar
Lower Alabama , USA
Very nice job Brother M.
Alan
Air #64439
TAC AL-8
2019 Canopenian
Old 01-29-2014, 10:30 AM   #10
2014 22' FB Sport
Atlanta , Georgia
Has anyone modified that table in the U-shaped dinettes? I'm not a small guy, and that table is just too big. Since we'll probably never use it as a bed ...
Belbein is offline   Reply With Quote
Old 01-30-2014, 10:03 AM   #11
Alumitater's Avatar
2007 25' Safari
screen door from inside
Sorry it took me a bit to post interior shot looking out....got a bit of foul weather down here. Hope this helps....really no visible difference from the inside....just holds the heat or cool in.
Tom and Robin
Old 01-30-2014, 11:13 AM   #12
Skatiero's Avatar
1986 32' Excella
Canton , Georgia
Thank you for posting that, Alumitater! Great job-- it looks wonderful! Are the panels easy to remove and store when not in use?
Old 01-31-2014, 07:39 AM   #13
Alumitater's Avatar
2007 25' Safari
They sure would be, thanks to the great choice of the clips Brother Al made. Simply loosen the screws, rotate the clip and remove the panel. Then tighten the screws back down to hold the clips in place without the panel. Roadtoaster and Brother Al get all the design credit.....I just copied their good ideas.
Tom and Robin
Old 05-18-2014, 05:06 AM   #14
palmtreegirl's Avatar
2008 25' Safari FB SE
Medina , Ohio
I'm going to have to do this! I hate having the door closed. Thanks!
Liz, Brian and 3 Yorkies
The Silver Pearl & The Black Pearl
2008 25' Safari FB SE Queen converted to King
2014 Ford Expedition EXP Limited 4x4 V-8
McKesh towing mirrors
Centramatic Balancers
Hensley Swift-Arrow Hitch
palmtreegirl is offline   Reply With Quote
