Old 06-11-2014, 08:23 AM   #15
palmtreegirl's Avatar
2008 25' Safari FB SE
Medina , Ohio
I have very small dogs so I took the bottom screen guard off and moved the small top one to the bottom. It totally works!
Liz, Brian and 3 Yorkies
The Silver Pearl & The Black Pearl
2008 25' Safari FB SE Queen converted to King
2014 Ford Expedition EXP Limited 4x4 V-8
McKesh towing mirrors
Centramatic Balancers
Hensley Swift-Arrow Hitch
palmtreegirl is offline   Reply With Quote
Old 06-11-2014, 08:26 AM   #16
Medina , Ohio
***"Fair warning - you take a chance of cracking the acrylic sheet on the table saw and/or band saw since it is brittle by nature. I have learned this the hard way many times over the years."***
Are there any tricks to cutting to avoid cracks? Tape on the cut line, perhaps?
Old 06-11-2014, 07:59 PM   #17
GreggH's Avatar
2005 31' Classic
Castalain Springs , Tennessee
Got motivated
Have been wanting to do this to the screen door for over 3 years and this thread finally motivated me to get it done. Did it today following the recommended supplies and was the simplest and least expensive alteration yet. I took our screens off and removed the grills and was amazed on how it opened up the view. We are leaving on a 3 month trip so will bring the grills with us in case my wife wants them back up but without them, it really brings the outside inside. Great thread with instructions worth following.
GreggH
GreggH is offline   Reply With Quote
Old 06-12-2014, 10:00 AM   #18
Alphonse's Avatar
2010 28' Flying Cloud
Lower Alabama , USA
I just use a fine toothed carbide tipped cabinet grade blade and go slow. Tape is a good idea too.
Alan
"If you must choose between two evils, pick the one you never tried before!"
Air #64439
Southeastern Camping Unit WBCCI #5033
TAC AL-8
2018 Canopenian
Alphonse is offline   Reply With Quote
Old 06-11-2015, 04:00 PM   #19
Vintage Kin
slowmover's Avatar
Fort Worth , Texas
Hadn't ever thought of this. A nice idea!
Old 06-12-2015, 04:44 PM   #20
airdreamers's Avatar
2008 28' International
Venice , Florida
Images: 14
Since this thread has be resurrected. I will put in my 2 cents
I always liked the open door idea. With the weather, heat and cold not practical to have the screen all the time, SO. I saw the plexi installed by another member of our Suncoast Unit in FL. What he did is a very professional way to do it. Obviously cut the plexiglass to fit the 2 panels where the screens are and use fasteners to hold the in place. The fasteners are held in by machine screws screwed into Rivnuts. What is a Rivnut, you ask?? Well it is like a rivet with the center of it being a female thread. It is installed similar to the way a rivet is installed but with a different tool that attaches to thread to squeeze. The screw at this point holds the fastener turn tab to hold the Plexi in place. I will attempt at a future date to post some pictures. BTW the tool is available at Harbor Frieght and it comes with several sized Rivnuts. What is nice about the Rivnuts is you can remove the screws and all there is is a fmale thread insert in the frame of the door, very neat looking.
Bill and Janice, We're lovin' it! (Airstreaming)
Airdreamers
WBCCI #8880
AIR #41310
airdreamers is offline   Reply With Quote
