Old 08-31-2006, 03:37 PM   #1
Cindy
1959 18' "Footer"
Powell River , British Columbia
stopping road grit from sneaking in the rear window
Hi Everybody,
I need to get the rear window of my 59-60 Traveler to close tightly enough to keep the road grit out.
It has the older openers with double ended handles on each side and no bottom lock like the newer windows.
Do I need to add a lock somehow? If so what have you used?
Could it be the weather stripping on the window frame?
Has anyone encountered this problem? Please advise!
Cindy
cindy is offline   Reply With Quote
Old 08-31-2006, 03:58 PM   #2
Tom Nugler's Avatar
1972 25' Tradewind
McHenry County , Illinois
First thought is that the weatherstrip is probably hard and no longer seals well. Second, and this happens to us every trip, is that air filters in through the rear access hatch and blows the accumulated grime out from around the cabinets and toilet.
I keep trying to seal things up but still find that layer of old trailer detritus blown is along the back wall.
Just a thought,
Tom.
AirForums # 2806
WBCCI / VAC # 6411
Not All Who Wander Are Lost.
Avid supporter of trailing edge technology.
Tom Nugler is offline   Reply With Quote
Old 08-31-2006, 05:18 PM   #3
CaddyGrn's Avatar
1963 16' Bambi
Yreka , California
Hello,
I agree it is likely the weatherstripping. You might try that first. If you don't think that is the problem... you might see if when you are driving if your overhead vents aren't quite sealed, or the vent over your stove... I would think they would create a suction of some sorts and pull dust in. I do not know the layout of your Airstream, but our Bambi has the stove top right by the rear window. We made little rubber stopper thingys we put in the vent on the outside before we drive to block the suction. Haven't had much trouble with dirt and grime coming in... we have new window seals as well.
Here is a link to pictures and general information about our vent and this issue... Scroll down to about post #383
http://www.airforums.com/forum...-17925-28.html
Good luck! If you find a sure fire solution be sure and post it!
Mrs. NorCal Bambi (traveling in S Tardis)
CaddyGrn is offline   Reply With Quote
Old 09-02-2006, 10:51 AM   #4
Originally Posted by cindy
Hi Everybody,
Cindy
Cindy.
Your problem is very common.
The window gaskets used on the vinatge windows, by todays standards, was extrememly poor.
A new type "D" shaped hollow gasket is now used as a replacement. It has superior sealing qualities, along with a long life span, provided you coat it once a year or so with silicone spray, which any of the newer styles gaskets require as well.
It's the junk in the air that we breathe, that attacks rubber gaskets.
Leak at rear bedroom wall Kirby Stone Leaks - Weatherstrips, Gaskets, Caulks & Sealants 15 02-12-2010 11:41 AM
Minuet Front Window Rock Guards overlander64 All Argosy Trailers 54 12-01-2003 09:13 PM
Wet floor, finding & stopping leak Joseph O. Smith Repairing/Replacing Floor &/or Frame 4 03-24-2003 10:17 PM
Window condensation????? Anna Windows & Screens 1 10-28-2002 10:51 PM
Broken Window Installation Charcigar Windows & Screens 2 07-30-2002 04:22 PM
