Old 08-27-2014, 05:16 AM   #1
SteveSueMac's Avatar
2012 27' Flying Cloud
W , New England
Stone Guard Window Gaskets
The gaskets that hold the plexiglass in the frame of the stone guards on my 2012 27fb Flying Cloud are coming loose at the corners.
The pic below is of one corner of the (open) center stone guard - the gasket is coming lose from all 4 corners on this guard.
On the 2 side guards, the gasket is coming loose on the upper inner (rounded) corner closest to the center guard - in other words, if you're looking at it from the front, the left guard's top right rounded corner and the right guard's top left rounded corner.
While still under warranty, I intend to include this on the list of things for the dealer to address at the end of the season but I have 2 questions I could use your help with:
1) assuming this is "normal", I'll likely be doing this myself every couple years or so. What tools/process should I use to re-stuff these gaskets (including the left/right removal process - haven't done that before...). I tried pushing the center window's gasket in by hand but it didn't want to play along!
2) is this something that can wait a month and 3 more outings before bringing to the dealer or should this be fixed ASAP? Are the windows going to fall out of the frames?
Thanks!
Old 08-27-2014, 05:27 AM   #2
Air-Texas's Avatar
2004 34' Classic S/O
Waldorf , Maryland
Mine does this too; I just push the gasket back into place with a screwdriver.
One day I might replace all of the gaskets, but for now, they are still flexible.
I have already replaced the gasket that goes between the frame and the skin
Mike, Miho &
Dallas the Bourbon Boxer
S/OS#069
TAC # TX-33
WBCCI #5702
AIR #60387
"Eva" 2004 Classic Limited 34' S/O
"Wall-E" 2012 Ford F250 King Ranch
Air-Texas is offline   Reply With Quote
Old 08-27-2014, 05:35 AM   #3
Wayne&Sam's Avatar
2014 25' Flying Cloud
Cuddebackville , New York
Images: 21
My '07 did that and they kept popping out again after I pushed the gasket back in. Finally I just cut it at the corner and then pushed it back in.. Problem solved.
2012 Dodge Durango Hemi/AWD
Old 08-27-2014, 06:43 AM   #4
dznf0g's Avatar
Oswego , Illinois
Order some new cording (I'm having a pre-senior moment...can't remember what it is called!). Ace has it...it is a thicker dimension than normal household screen spline (I remembered!) When you install it, don't let it stretch. That is why it works out. Use your spline tool, rolling TOWARD the portion already in place. This compresses the spline, rather than stretching it.
-Rich-
Old 08-27-2014, 07:10 AM   #5
dkrug's Avatar
2012 30' International
Bad Axe , Michigan
Ours did on the 2005 and on this one. We did what Wayne&Sam did and snipped the corner.
2012 30' International Serenity
1947 Spartan Manor
2005 28' Safari LS - traded
1977 31' International Sovereign - sold
2012 Ford F250 Superduty Crewcab
WBCCI# 1007 Air#2158
dkrug is offline   Reply With Quote
stone guard question... safari05-25 Rock Guards, Segment & Window Protectors 2 10-05-2006 07:23 PM
Window Stone Guard What to do? GT1963 Rock Guards, Segment & Window Protectors 30 08-31-2006 09:49 PM
Looking for a stone guard -1976 Argosy James Martin Rock Guards, Segment & Window Protectors 5 11-28-2005 07:49 PM
Lower Stone Guard Repair cesurman Rock Guards, Segment & Window Protectors 1 08-15-2002 07:22 PM
Stone Guard/ Keep it or Remove it? 74Tradewind Rock Guards, Segment & Window Protectors 9 06-26-2002 01:09 PM
