Old 08-25-2007, 08:33 AM   #15
CanoeStream's Avatar
St. Cloud , Minnesota
Hi Peter - We've had a different thread come through earlier this summer on this same issue. Somebody seemed to come up with the actual manufacturer's recommendation to remove dust & films with mild soapy water and follow up by spreading a light film of petroleum jelly on the gasket. I put on silicone in the spring and they're sticking again. I'm trying this latest recommendation next.
5 meter Langford Nahanni
Old 08-25-2007, 09:23 AM   #16
lewster's Avatar
Naples, FL , Hood River, OR
Hey Bob,
Go to Lowes and get a can of 'DuPont Multi-Purpose Teflon Dry Lube' and spray it on the gaskets. It dries to a film that will not attract dust or dirt and will solve your sticking problems.
I use the stuff on almost everything from bicycle and motorcycle chains to hinges and awnings when getting installed. GREAT PRODUCT!
Old 08-25-2007, 09:31 AM   #17
Sounds better yet - thanks Lew!
Old 07-13-2008, 04:00 PM   #18
ESCAPE POD's Avatar
2007 19' Safari SE
Seal Beach , California
Open & lift window from outside
It's good to apply silicone to the window gaskets, but I've found it easier, on our '07 Bambi, to lift and position the windows from the outside (once they are unlatched). The various track positions are easier to reach from the outside than hunching over the dinette table to lift the window from the inside. Besides, you have to open the outer center panel from the outside anyway.
"I have found through trial and error that I work best under duress. In fact, I work only under duress." -Ed Abbey
Jerry & Susan
2007 19' Bambi SE; 2010 Ford F-150 5.4L SuperCrew 4x4 w/ FlipPac camper shell
ESCAPE POD is offline   Reply With Quote
Old 07-13-2008, 04:06 PM   #19
Beneath the title
jnerges's Avatar
2005 28' International CCD
Mount Pleasant , South Carolina
Originally Posted by Foiled Again View Post
(Guys use duct tape, women grab a piece of silverware!)
Paula Ford
Not True, I used a butter knife...
Aunt Gladys, 28FT, Intl'
"Man, it's hot here, is the heat on?"
jnerges is offline   Reply With Quote
Window latch dilemma maxandgeorgia Windows & Screens 5 05-18-2018 10:35 AM
1974 Excella front window docu post john hd 1973-1974 Excella 500 22 08-06-2004 01:53 PM
Try this!! Window frame oxidation removal trick... niftypkg Cleaning, Stripping & Polishing 2 08-23-2002 05:49 AM
Front Wing Window Repair Charles D. Bennett Windows & Screens 0 08-10-2002 06:04 PM
Window Frame Removal 64GT Windows & Screens 4 04-09-2002 12:40 PM
