Sticky window gasket
[My web connection died, so this is a re-post] I just bought a new 2007 19' Safari SE, and the front inner window pane gets stuck to the window gasket, to the point that I have to get out and use a coin to gently pry the pane loose from the gasket. Any suggestions for a gasket treatment to eliminate the sticking (petroleum jelly, etc?).
"I have found through trial and error that I work best under duress. In fact, I work only under duress." -Ed Abbey
Jerry & Susan
2007 19' Bambi SE; 2018 Ford F-350 5.4L SuperCrew 4x4
