12-31-2016, 07:12 AM
2017 25' Flying Cloud
Florence
, Alabama
Sticking Windows
Does anyone have a fix for sticking Windows? Without fail when I go to open any Windows they're stuck and I end up going outside to pry open. I've tried silicone but they still stick after a while. A little mechanical lever on the inside to push the window out and break the seal would have been nice
DBLee and Southern Belle on the road
The Colonel and Southern Belle
12-31-2016, 08:43 AM
2014 30' Flying Cloud
Tampa
2014 Airstream Flying Cloud 30 Recliner - WBCCI #4850 - AIR #110821
2018 Nissan Armada SL Tow Vehicle, Equal-i-zer Hitch
Visit Our Flying Cloud blog for my latest adventure!
2017 27' Flying Cloud
Goode
, Virginia
I've used 303 Protectant on the windows of our 2015 FC with some success. I apply it with a microfiber cloth several time a year.
I came across this mechanical solution ( http://www.seeyoudowntheroad.com/window-poppers/) but have not used it.
When we took delivery of our new 2017 I noticed that all the window gaskets had something on them from the factory that does keep them from sticking but attracts dirt and leaves a residual on the window. Not sure what is is but I don't like how messy it is so I haven't contacted JC to find our what it is. For now I'm going to continue using the 303.
12-31-2016, 09:32 AM
Florence
, Alabama
Originally Posted by FCStreamer
The window poppers seem to be just what I was looking for. Wonder if anyone is using them?
12-31-2016, 09:49 AM
2005 30' Classic
Burlington
, Ontario
I've tried armorall and 303 without a whole lot of success. Probably because we don't tend to open the windows a whole lot.
I was thinking to buy the windowpopping gadgets but not sure if it is worth it if doing all the windows - which I probably would want to if going that route.
I've also heard of people just driling a small hole in the frames and using a wooden dowel to push. A cheaper alternative I guess. In fact I suppose you could leave short dowel push sticks at each window and secure them in place with a couple of O rings as a slightly better arrangement.
I just carry a large suction cup thingy and pull them open fro outside the first time on a trip if we want to use them. After that they are fine for the balance of that trip!
Brian.
Brian & Connie Mitchell
2005 Classic 30'
Hensley Arrow / Centramatics
12-31-2016, 10:47 AM
2007 27' Classic FB
Ridgefield
I use the 303 and apply it a couple of times a year. Purchased a plastic tool at an RV store that helps gently pry the stuck window and seal apart. There hasn't been much need for the tool since I started a regular maintainece plan.
John
12-31-2016, 11:19 AM
Washington
, Missouri
Here is a related thread when I was having trouble with my Fantastic Vents seals.
http://www.airforums.com/forums/f454...ml#post1826784 post #30
Seems the manual talks about 303 re the windows but the vent fan seals suggested a 100% silicone oil. I figured seals are seals. When I called FV the suggested the 100% silicone oil but they didn't sell it any more. She suggest air gun oil. The local dealer said the same thing and suggested seals are seals and the oil would be preferred on the window seals. It also should be noted the FV indicated the 303 for the fan dome only as a protectant not as a seal softener.
I found this on Amazon but there are others. This mf't confirmed the 100% silicone content...others were not specific.
https://www.amazon.com/Airsoft-Gun-L...e+silicone#Ask
A few others on forums suggested dry spray on lubricate...
https://www.walmart.com/ip/SPRAYON-S...0-oz./41213769
My experience last summer with the silicone oil was good but I haven't tried the lately nor re-applied it. Unfortunately I had a medical issue and Blue has been sitting idle since late August. I suspect I'll be reapplying another coat this spring.
However I must admit the window poppers look like a great mod. I was using a small plastic putty knife before the oil.
01-01-2017, 06:26 AM
Florence
, Alabama
Well I ordered a four pack to see how they do. Think I'll try the air gun oil in the meantime.
01-01-2017, 07:27 AM
2020 30' Classic
2016 30' Classic
Covington
, Louisiana
I've used olive oil On the seals with some success!
01-01-2017, 07:34 AM
2012 25' FB International
Trent Woods
, North Carolina
The best thing I have ever found is dielectric grease found at electronic shops and auto supply. High end cars use that grease for their weather seals. A light coat twice year on my AS window seals keeps them stick-free.
Larry
01-01-2017, 08:04 AM
2015 30' Classic
2012 28' International
Greensboro
, North Carolina
I've put window poppers on all the windows in my Classic (I also used them on my Intl). They ALWAYS work. Frankly, I tried everything else and just got tired of spraying silicone, using silicone grease and every other compound mentioned in this thread. So much easier to push a little black button and KNOW the window will open.
_________________
"SilverLeaf II" 2015 30' Classic
2019 RAM 2500 Limited 4x4 CC w/6.7L Cummins
ProPride 3P
AIR# 58452
WBCCI # 3430-Unit 21
01-01-2017, 09:39 AM
Fayetteville
, Arkansas
I treat my seals with silicone to keep them pliable. I then wipe the glass edge with talcum power to dry the contact area. We do this twice a year as part of the exterior deep clean and waxing. Still going to install the poppers as it seems to be a great add.
FishByFly
because I catch fish on a fly...
2017 25' FB Flying Cloud Queen
2010 F250 Lariat
FishByFly
2017 25' Safari FBQ - “Fly Fish Inn”
2023 F150 XLT
01-01-2017, 11:33 AM
2013 31' Classic
billings
, Montana
I have a plastic tool used for windshield replacements to pry my windows open,it gets used a lot, most times you have to pry in two places, Good exercise...
02-24-2017, 07:32 PM
Florence
, Alabama
I put my four pack on a while, had to open windows today. All stuck until I used the poppers! Great little helpers
02-24-2017, 09:06 PM
1972 25' Tradewind
McHenry County
I've got two solutions that may work for you. One high tech, one old school.
VW Group has had issues with the rubber seals on hardtops and panoramic sunroofs. Squeaks, leaks, binding, ect. Silicone is verboten.
Clean the seals and apply “Special Lubricant” G 052 172 A1. Ridiculously expensive but solves all the problems related to rubber gasketing.
Some say this is the same stuff as DuPont Krytox that GM used to stop “T” Tops from sticking on Vettes and Cameros.
The old school method is plain old J+J Baby Powder. We would rub this into the rubber seals on Bug convertables. Couldn't stop leaks, nothing did, but the glass wouldn't bind or stick, seals didn't collect dirt, was dirt cheap and smelled good.
Good Luck,
Tom
