Old 05-17-2009, 11:33 AM   #1
1994 34' Excella
Warren , Manitoba
Stack window repair
I have taken the lexan inside pane out and am ready to remove the outer glass pane. The PO used silicone and god knows what else to try and seal the window. The Vulkem has got on the lexan and is very sticky and a mess. What do you use to clean the lexan, or is it better to replace the piece with a new one? Unit is a 1976 31' international. Thank you for any help
CBWELL is offline   Reply With Quote
Old 05-17-2009, 01:30 PM   #2
bullydogsmom's Avatar
1972 25' Tradewind
old mystic , Connecticut
If the vulcum has dried someone on here suggested WD-40 leave it on a few minutes and wipe it off. If it's still sticky I have removed it with mineral spirits.
Annette
bullydogsmom is offline   Reply With Quote
Old 05-17-2009, 05:48 PM   #3
1994 34' Excella
Warren , Manitoba
Thank you, worked great. Now to remove the glass, clean it up and install some tint. I think that I will use butyl glazing tape to reinstall the glass. Hopefully it will not "run" as the vulkem did. Then can seal the outside with a thin bead of vulkem.
How Does This stack up to an 21-22 ft. AS? gc24 Member Introductions 8 06-04-2008 10:20 PM
window repair Judy Barde Windows & Screens 7 11-26-2006 07:42 AM
Window Repair 68LANDYACHT Windows & Screens 0 10-18-2004 08:30 AM
Vent stack covers silverhawk Roof Vents, Skylights & Fans 3 02-03-2004 04:35 PM
roof stack gaskets bhsl8 Leaks - Weatherstrips, Gaskets, Caulks & Sealants 5 09-25-2002 05:29 PM
