Old 10-17-2011, 08:29 AM   #1
projector's Avatar
1972 23' Safari
NSB , Florida
Sliding window screen install
I'm sure this has been covered but I don't have time to search for it. Our '75 Argosy MH came with a loose framed screen for the curb side dinette windows. What is the trick to install it without destroying the frame?
We're camping this weekend in a park without hook-ups.
thanks.
projector is offline   Reply With Quote
Old 10-17-2011, 08:36 AM   #2
raveson's Avatar
1989 34.5' Airstream 345
boca raton , Florida
If the build is the same as my89 345, at either side of lower track is a plastic channel. There should be a small screw to each side. Remove the screws and the channel should slide out. This then leaves you enough room to remove the frame and replace the screen. Be sure to get new spline at this time or you will be removing it again. Good luck!
raveson is offline   Reply With Quote
Old 10-17-2011, 08:51 AM   #3
projector's Avatar
1972 23' Safari
NSB , Florida
I'll have to check it at lunch but I don't remember seeing what you're describing. The frame/track it slides in it continuous, the full peremiter of the window. thanks.
Old 10-17-2011, 12:03 PM   #4
projector's Avatar
1972 23' Safari
NSB , Florida
Here's a pic.
Name:	window screen 003.jpg
Here's a detail of another window with a screen.
Name:	window screen 002.jpg
The window slides in the outer track, the screen slides in the inner track.
thanks.
Old 10-17-2011, 12:38 PM   #5
Originally Posted by projector View Post
Here's a pic.
Attachment 142970
Attachment 142971
thanks.
Flex the screen, CAREFULLY.
Old 10-17-2011, 01:24 PM   #6
projector's Avatar
1972 23' Safari
NSB , Florida
What size hammer should I use?
Old 10-17-2011, 02:02 PM   #7
Use a 287 pound 4 3/4 ounce sledge hammer.
Seriously, flex the screen carefully, and then have a cool one.
Old 10-17-2011, 03:12 PM   #8
projector's Avatar
1972 23' Safari
NSB , Florida
I'll try again. The glass behind it limits how much it will flex, on the forward edge anyway.
thanks.
Old 10-17-2011, 03:16 PM   #9
thanks.
Your correct, none-the-less, that's how it's done.
Be patient.
AS280 - Front (driver) sliding window latch dalefox Classic Motorhomes 14 09-13-2018 09:05 PM
Screen for Bambi rear window Gsnedike Windows & Screens 8 07-24-2015 07:26 PM
Window Screen Replacement - 2011 FC23FB JamuJoe Windows & Screens 2 09-20-2011 09:18 AM
Rear window screen pass through-pet door triterra Windows & Screens 4 07-19-2011 08:43 PM
