Old 07-26-2011, 10:01 AM   #1
NoMoSOBs's Avatar
1998 30' Excella 1000
Aylett , Virginia
Images: 14
Shattered window in '98 Airstream- advice needed
I have a shattered panoramic (?) or corner wrap-around window in my 1998 Excella. I need to replace it quickly for an upcoming trip. I know this is probably blasphemy, but has anyone used lexan as a temporary solution, and how difficult is the replacement? It looks like the window can be removed from the outside without removing any interior panels, correct? I am really not concerned with aesthetics, as the window is behind a rock guard and a curtain on the inside, but I need it to not leak. Any suggestions or advice? Is it possible to remove the whole frame and have it repaired by a local glass shop? Has anyone had any luck finding these used? I've e-mailed a couple of salvage yards and had no response yet.
John T.
TAC VA-16
NoMoSOBs is offline   Reply With Quote
Old 07-26-2011, 10:12 AM   #2
c_lewis77's Avatar
1982 34' Limited
Brunswick , Georgia
Images: 22
I used lexan. Make a good template with cardboard and transfer, the window is shaped funny when flat. Also make sure you a sharp blade; i used a jig saw. Any "jumps" in the cut may cause it to crack when ypu bend it to the curve.
Its a good temp fix untill you can get the glass replaced.
Good luck!
1982 34' Limited
2000 Excursion V10 4x4
WBCCI #3321
TAC #GA-24
c_lewis77 is offline   Reply With Quote
Old 07-26-2011, 11:05 AM   #3
Well Preserved
overlander63's Avatar
1993 21' Sovereign
Colfax , North Carolina
You do know those are still available from any Airstream dealer?
Old 07-26-2011, 11:06 AM   #4
c_lewis77's Avatar
1982 34' Limited
Brunswick , Georgia
Images: 22
How fun is that? Lol!
1982 34' Limited
WBCCI #3321
TAC #GA-24
Old 07-26-2011, 12:51 PM   #5
NoMoSOBs's Avatar
Aylett , Virginia
Images: 14
Good luck!
Thanks- at least I know it is possible. A few questions- did you have to remove the window frame to install the lexan? If not, I assume you did it from the outside? What did you use to fasten it to the frame? Did you have to heat the lexan to bend it, or would it flex that much? Thanks!
John T.
TAC VA-16
Old 07-26-2011, 12:54 PM   #6
NoMoSOBs's Avatar
Aylett , Virginia
Images: 14
Yes but...
I'm still recovering from the price I was quoted... safe to assume that the current budget does not allow for that expenditure in the immediate future.
John T.
TAC VA-16
Old 07-26-2011, 01:04 PM   #7
Silver Otter's Avatar
2011 31' Classic
Nellysford , Virginia
Images: 8
John,
I'm interested in this thread. Hoping to learn-by-lurking here. Our Excella is similar to yours. Yay for Virginia Excellas! Are you coming to the Commonwealth Rally in Louisa in September? I'd love to see how the repairs come out.
Linda Heuer. President Shen. Valley Unit
Greg Heuer, 2nd VP Shen. Valley Unit
2011 31' Classic Ltd. - The Silver Otter III
2013 GMC Denali 2500HD 6.6 DuraMax - Sierra Blanca
TAC VA-18 | WBAC 1927 - Shen. Valley Unit 149 | AIR 53869
with Corey, the Norwegian Forest Cat
Silver Otter is offline   Reply With Quote
Old 07-26-2011, 01:07 PM   #8
c_lewis77's Avatar
1982 34' Limited
Brunswick , Georgia
Images: 22
I applied it to the exterior. I predrilles the frame on the as and the lexan, applied a gasket to the frame and used wode flange sheet metal screws to secure. I layed out the screw holes symmetrically so it looks more "intentional". Bend the lexan carefully; it is a two man job. One to hold one to fasten. I caulked around the exterior for extra waterproofing (belt and suspenders).
The correct fix of course, is to replace the window. The lexan has worked good for me as a "long term temp" solution and it is cheaper. I have had no issues with leaks from the window so far. And, like you mentioned, the rock guard covers it. On the inside you dont really notice.
1982 34' Limited
WBCCI #3321
TAC #GA-24
Old 07-26-2011, 01:16 PM   #9
NoMoSOBs's Avatar
Aylett , Virginia
Images: 14
Thanks c lewis. That's exactly what I needed to know. I'm hoping a used supplier will come through for me, but if that doesn't happen before our trip, I will be going the lexan route.
John T.
TAC VA-16
Old 07-26-2011, 01:20 PM   #10
c_lewis77's Avatar
1982 34' Limited
Brunswick , Georgia
Images: 22
Good luck!
That window is still on my "captains list", just further down now
1982 34' Limited
WBCCI #3321
TAC #GA-24
Old 07-26-2011, 01:31 PM   #11
NoMoSOBs's Avatar
Aylett , Virginia
Images: 14
Originally Posted by gheuer View Post
John,
Hi Greg,
Always nice to see a fellow Virginian on the forums! I'm only 45 minutes NE of Richmond, and approx an hour from Louisa, so I will have to check out that rally. I've never been to one. I don't know if my Excella will be ready for that, as it is something of a work-in-progress. It was damaged by a previous owner not chocking it properly. It slipped the jack and rolled into the nearby woods, sustaining damage on the rear curbside panels and front by the entry door (shattering the curved window.) I've popped the dented panels back out enough for it to be servicable, and will eventually seek replacements but for now we are anxious to hit the road. After owning two "vintage" Airstreams- a 1963 Tradewind and a 1971 Sovereign, and being completely overwhelmed by the scope of the work needed, I'm looking forward to using this one as-is.
John T.
TAC VA-16
Old 07-26-2011, 01:35 PM   #12
NoMoSOBs's Avatar
Aylett , Virginia
Images: 14
P.S.- Greg, if you have any info on the rally I'd sure appreciate it. Also, how is that clearcoat on your Excella holding up?
John T.
TAC VA-16
Old 07-26-2011, 01:37 PM   #13
toddster's Avatar
1967 20' Globetrotter
Campbell , California
I've got a roadside-front/curbside-rear NOS panoramic window that I'd be willing to sell for 1/2 of retail. Not sure of the exact years for the application, but it is certainly for the newer models - the Airstream part number is 372088-101. Let me know if this would work for you.
toddster is offline   Reply With Quote
Old 07-26-2011, 02:55 PM   #14
2011 31' Classic
Images: 8
Here, if I can do it, are two small pages on the rally. Our clearcoat is pristine. The PO took really good care of the unit, and the 1999 year was the first year, research seems to indicate, that Alcoa bonded the clearcoat to the panels during fabrication.
'69 Globetrotter with shattered window. Help!! montanablue Windows & Screens 8 06-26-2011 06:58 AM
NorCal : Airstream needed for horror movie! marsfeehery Forum Rallies & Meet Ups 5 05-18-2011 11:19 PM
