07-26-2011, 10:01 AM
1998 30' Excella 1000
Aylett
, Virginia
Shattered window in '98 Airstream- advice needed
I have a shattered panoramic (?) or corner wrap-around window in my 1998 Excella. I need to replace it quickly for an upcoming trip. I know this is probably blasphemy, but has anyone used lexan as a temporary solution, and how difficult is the replacement? It looks like the window can be removed from the outside without removing any interior panels, correct? I am really not concerned with aesthetics, as the window is behind a rock guard and a curtain on the inside, but I need it to not leak. Any suggestions or advice? Is it possible to remove the whole frame and have it repaired by a local glass shop? Has anyone had any luck finding these used? I've e-mailed a couple of salvage yards and had no response yet.
John T.
TAC VA-16
07-26-2011, 10:12 AM
1982 34' Limited
Brunswick
, Georgia
I used lexan. Make a good template with cardboard and transfer, the window is shaped funny when flat. Also make sure you a sharp blade; i used a jig saw. Any "jumps" in the cut may cause it to crack when ypu bend it to the curve.
Its a good temp fix untill you can get the glass replaced.
Good luck!
1982 34' Limited
2000 Excursion V10 4x4
WBCCI #3321
TAC #GA-24
07-26-2011, 11:05 AM
Retired.
, At Large
You do know those are still available from any Airstream dealer?
07-26-2011, 11:06 AM
1982 34' Limited
Brunswick
, Georgia
How fun is that? Lol!
1982 34' Limited
WBCCI #3321
TAC #GA-24
07-26-2011, 12:51 PM
Aylett
, Virginia
Good luck!
Thanks- at least I know it is possible. A few questions- did you have to remove the window frame to install the lexan? If not, I assume you did it from the outside? What did you use to fasten it to the frame? Did you have to heat the lexan to bend it, or would it flex that much? Thanks!
John T.
TAC VA-16
07-26-2011, 12:54 PM
Aylett
, Virginia
Yes but...
I'm still recovering from the price I was quoted... safe to assume that the current budget does not allow for that expenditure in the immediate future.
John T.
TAC VA-16
07-26-2011, 01:04 PM
2011 31' Classic
Nellysford
, Virginia
John,
I'm interested in this thread. Hoping to learn-by-lurking here. Our Excella is similar to yours. Yay for Virginia Excellas! Are you coming to the Commonwealth Rally in Louisa in September? I'd love to see how the repairs come out.
Greg Heuer, Spirit of Virginia Airstream Club
2011 31' Classic Ltd. - The Silver Otter III
2013 GMC Denali 2500HD 6.6 DuraMax - Sierra Blanca
TAC VA-18 | Life Mbr ACI 1927 - Spirit of Virginia Club | AIR 53869
07-26-2011, 01:07 PM
1982 34' Limited
Brunswick
, Georgia
I applied it to the exterior. I predrilles the frame on the as and the lexan, applied a gasket to the frame and used wode flange sheet metal screws to secure. I layed out the screw holes symmetrically so it looks more "intentional". Bend the lexan carefully; it is a two man job. One to hold one to fasten. I caulked around the exterior for extra waterproofing (belt and suspenders).
The correct fix of course, is to replace the window. The lexan has worked good for me as a "long term temp" solution and it is cheaper. I have had no issues with leaks from the window so far. And, like you mentioned, the rock guard covers it. On the inside you dont really notice.
1982 34' Limited
WBCCI #3321
TAC #GA-24
07-26-2011, 01:16 PM
Aylett
, Virginia
Thanks c lewis. That's exactly what I needed to know. I'm hoping a used supplier will come through for me, but if that doesn't happen before our trip, I will be going the lexan route.
John T.
TAC VA-16
07-26-2011, 01:20 PM
1982 34' Limited
Brunswick
, Georgia
Good luck!
That window is still on my "captains list", just further down now
1982 34' Limited
WBCCI #3321
TAC #GA-24
07-26-2011, 01:31 PM
Aylett
, Virginia
Originally Posted by gheuer
John,
Hi Greg,
Always nice to see a fellow Virginian on the forums! I'm only 45 minutes NE of Richmond, and approx an hour from Louisa, so I will have to check out that rally. I've never been to one. I don't know if my Excella will be ready for that, as it is something of a work-in-progress. It was damaged by a previous owner not chocking it properly. It slipped the jack and rolled into the nearby woods, sustaining damage on the rear curbside panels and front by the entry door (shattering the curved window.) I've popped the dented panels back out enough for it to be servicable, and will eventually seek replacements but for now we are anxious to hit the road. After owning two "vintage" Airstreams- a 1963 Tradewind and a 1971 Sovereign, and being completely overwhelmed by the scope of the work needed, I'm looking forward to using this one as-is.
John T.
TAC VA-16
07-26-2011, 01:35 PM
Aylett
, Virginia
P.S.- Greg, if you have any info on the rally I'd sure appreciate it. Also, how is that clearcoat on your Excella holding up?
John T.
TAC VA-16
07-26-2011, 01:37 PM
I've got a roadside-front/curbside-rear NOS panoramic window that I'd be willing to sell for 1/2 of retail. Not sure of the exact years for the application, but it is certainly for the newer models - the Airstream part number is 372088-101. Let me know if this would work for you.
07-26-2011, 02:55 PM
2011 31' Classic
Nellysford
, Virginia
Here, if I can do it, are two small pages on the rally. Our clearcoat is pristine. The PO took really good care of the unit, and the 1999 year was the first year, research seems to indicate, that Alcoa bonded the clearcoat to the panels during fabrication.
07-26-2011, 08:06 PM
Aylett
, Virginia
Thanks Greg. I will try to make it. You're lucky on the clearcoat. Mine is peeling in several spots above the beltline.
Todd, I think that may work. I will check the part # in the a.m. and message you.
I love this forum.
John T.
TAC VA-16
07-27-2011, 01:05 PM
Ready-to-Travel
2012 30' International
Walkerton
, Virginia
JohnT - we are just down the road from you in Walkerton. Our 31' Limited is also very similar. We should show off our rigs one of these days.
Greg, if we make the rally, it would be for Sat, as we will be heading west for the Fiesta around that time. It would be fun to meet you and your friends.
Are ex-wbcci'ers welcome?
Pat
Somebody, please, point me to the road.
AIR 3987
TAC VA-2
WBCCI 4596
07-27-2011, 07:02 PM
Aylett
, Virginia
Pat, small world. Walkerton is a beautiful little spot. Are you on the Mattaponi? I often put my boat in there for a quick fix.
John T.
TAC VA-16
07-28-2011, 08:22 AM
2011 31' Classic
Nellysford
, Virginia
VA Commonwealth Rally in Louisa
Pat
I'll check it out, Pat. I'm new to WBCCI and the Unit, so I'll ask a vet. More news soon. (Linda and I will lead the Trevilian Battle Tour, with a twist. )
07-29-2011, 01:14 PM
2011 31' Classic
Nellysford
, Virginia
Good news! Any Airstream is welcome at the Commonwealth Rally. No WBCCI required, although it's being hosted by our unit, #149. Pass the word if anyone would like to come by. The campground is simple , but nice.
