Old 06-25-2010, 10:41 PM   #1
bwaysteve's Avatar
1965 28' Ambassador
Irving , Texas
sealing windows
Do I need to remove my drip caps to seal the tops of the window frames?
bwaysteve is offline   Reply With Quote
Old 11-10-2010, 05:27 PM   #2
1963tradewin's Avatar
1963 24' Tradewind
, , Minnesota
I did mine without removing drip caps. Just make sure you get all that silicone etc. out from around the windows. I found silicone remover from Vintage Trailer Supply works great.
Psalm 67:7
1963tradewin is offline   Reply With Quote
Sealing the Vista View Windows Gkiesel Leaks - Weatherstrips, Gaskets, Caulks & Sealants 22 10-12-2017 11:42 AM
Weather Sealing windows in 1958 Overlander mello mike Windows & Screens 0 05-20-2010 02:28 PM
Need Advice: Re-Sealing Windows & Replacing Table SueH Member Introductions 6 11-30-2006 03:35 AM
Use of Vulkem for sealing windows... TheCountess Windows & Screens 8 05-22-2006 07:43 AM
Sealing Windows & Caulking outside mgordon Leaks - Weatherstrips, Gaskets, Caulks & Sealants 3 01-13-2003 12:18 PM
