Old 03-17-2014, 06:49 AM   #1
Razinni's Avatar
1977 31' Sovereign
Atlanta , Georgia
Sealing Windows
We have two minor issues on our windows and when I read this forum I'm not always sure if people are talking about the gray gasket sealing the window itself or the weather stripping that goes around the inside of the window frame against the trailer.
1. For the window seal itself I have a couple windows where the gasket has pulled out of the corners. No visible leaking but I'd like to address this.
My plan here is to re-seat as much of the gasket as possible then use a silicon sealer to fill any gaps. I do not want to completely remove the existing gaskets as they are not leaking. Any feedback?
2. For the Window frames I've purchased the correct stripping I plan on applying.
We've brought the windows into the work area one by one and plan on removing the old weather stripping. It looks like a scrape job but I wonder if someone has a recommendation on removing the weather stripping. Is it just a razor blade or some miracle compound? (other than elbow grease)
Thanks for any feedback.
Raz
"The road goes on forever and the party never ends" - R.E.Keen
Razinni is offline   Reply With Quote
Old 03-19-2014, 04:33 PM   #2
huntingdon , Pennsylvania
i am wondering the same thing ... the windows look like they have a thin gray seal around the outside frame/ window. not sure if this can be puirchased or not
mine are coming out of the window frame on the corners
kokomoscalls is offline   Reply With Quote
Old 03-19-2014, 05:15 PM   #3
E Pluribus Aluminus
Jaxon's Avatar
2008 34' Classic S/O
1967 22' Safari
2005 30' Classic
Rockport , Texas
Send a message via AIM to Jaxon Send a message via Yahoo to Jaxon
Several great threads on sealing seams and windows on the forums. Use the search and any variation of sealing seams or sealing windows.
Amazing thing that search function!
Bill & Kim
WBCCI 7005 * AIR 9218
The trouble with trouble is it always starts out as fun...
Jaxon is offline   Reply With Quote
Old 03-19-2014, 06:01 PM   #4
Razinni's Avatar
1977 31' Sovereign
Atlanta , Georgia
Lol seriously I started with search but then again I can't find milk in the refrigerator.
Old 03-19-2014, 06:58 PM   #5
1981 31' Excella II
New Market , Alabama
The gray gasket is U-shaped and it can't be replaced without removing the window and taking the frame apart which is not something you want to do if you don't have to. What I did was cut the lip flush with the window frame and then put a bead of Trempro-635 polyurethane caulk. Don't use silicone. A razor blade or utility knife works great for this. If the gasket leaks, water can get inside the frame and then leak inside the trailer through the seams at the top and bottom of the window frame. Also water that gets between the glass and the gasket will eventually find its way between the two panes of glass and fog them.
This thread should help.
http://www.airforums.com/forums/f454...s-86615-2.html
Perry
Old 03-19-2014, 07:51 PM   #6
DryFly's Avatar
1972 Argosy 20
Snoqualmie , Washington
Perryg is right. I had a leak coming in from the front window after the first rain after I brought my Argosy home. Then I discovered Trempro and used it as Perryg has said (I just guessed though as I couldn't find anything on this forum about it) and it took care of the issue. I then did the same for all windows as they all were going to leak at some point.
Again, don't use silicone.
DryFly is offline   Reply With Quote
Old 03-29-2014, 10:49 AM   #7
retrocar66's Avatar
1967 24' Tradewind
Greenville , North Carolina
I've found that a plastic chisel works great for removing the old seals and adhesive. And it won't scratch the aluminum. I usually soften the adhesive with a little solvent (mineral spirits) first. Amazon sells the plastic chisels.
retrocar66 is offline   Reply With Quote
Windows or plexiglas ? Gaël Windows & Screens 44 06-30-2016 12:58 PM
Replacing windows in 1967 Overlander MAbdala Windows & Screens 12 05-15-2015 05:46 PM
Double Pane Windows perryg114 Windows & Screens 4 09-12-2011 04:30 PM
'73 Tradewind Windows Vista and Front Sides constructor Windows & Screens 8 01-28-2011 05:44 AM
