Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Windows, Doors, Locks & Vents > Windows & Screens
Old 01-27-2012, 11:02 PM   #1
1974 27' Overlander
Twisp , Washington
Screwy question...
Sorry, sometimes I crack myself up :-). And no, my wife doesn't appreciate my sense of humor, either.
I'm rebuilding all my windows, and luckily, none of the steel sheet metal screws holding the Plexiglas inner panes to the outer panes have been frozen or so corroded that they broke. But most of them are pretty rusty, so I'm planning on replacing all of them. My question is, should I stay with the galvanized screws, or would I be better off going with stainless steel? I know that electrolysis is an issue with dissimilar metals, but I can NOT remember if it's more or less of a problem with stainless vs. galvanized. Thanks.
Dave
daved20319 is offline   Reply With Quote
Old 01-28-2012, 02:17 AM   #2
NevadaGeo's Avatar
1978 31' Excella 500
Genoa , Nevada
Good question, zinc galvanized versus chrome stainless. I suspect the chrome will dissasociate less into the surrounding aluminum than the zinc. It would be nice if there was an aluminum screw strong enough to do the job.
You might try to repost this again in the daylite hours, the thread might disappear before morning.
I admit to being powerless over housecleaning and social niceities
Airforums 22655 and now, WBCCI 22655
NevadaGeo
NevadaGeo is offline   Reply With Quote
Old 01-28-2012, 08:23 AM   #3
samb's Avatar
1961 22' Safari
Union , Oregon
Images: 11
I have used stainless steel screws on aluminum trailers for years and have no problems with dissimilar metals corrosion.
Sam
samb is offline   Reply With Quote
Old 01-28-2012, 08:36 AM   #4
Ag&Au's Avatar
Port Orchard , Washington
The reason stainless stains less is because it is less reactive other substances. Galvenizing is coating iron or steel with zinc. So until the galvenizing is broken down, It wil react with other sutances as though it were zinc. Zinc is used in some appliocations as a sacrificial piece of metal allowed to deteriorate to provide corrosion protection to other metals. I would infer from this that galvenizing is not a excellent long term solution. Keep in mind that there are different grades of stainless and I have bought some that has rusted. I am sure the is some other way to identify good from bad stainless, but not knowing what that is for sure, I rely on price.
Ken
Old 01-28-2012, 08:50 AM   #5
Southwestern , Ohio
Go with the stainless screws. Although the nickel and chromium content of stainless steel could create a galvanic couple, it doesn't, because the thing that makes stainless steel "stainless" is that it forms an adherent oxide layer on the surface of the metal that prevents it from oxidizing further.
Nuvite-F is offline   Reply With Quote
Old 01-29-2012, 01:13 AM   #6
NevadaGeo's Avatar
Genoa , Nevada
Ken
Good stainless won't stick to a magnet, I don't think.
NevadaGeo
Old 01-29-2012, 03:04 AM   #7
1977 31' Sovereign
1989 34' Excella
Johnsburg , Illinois
300 series stainless steel is non-magnetic. Stain resistant 400 series is magnetic. Fasteners are usually 302 or 304. That is what I usually use. 400 series is capable of being hardened and can be used to make knifes that actually hold an edge. Don't buy a stainless steel knife that is non-magnetic.
Old 01-29-2012, 06:56 AM   #8
"Cloudsplitter"
Thumbs up
POI....replace ALL your exterior screws with stainless....clearance lights etc.
Ask me how I know.
.......yep.
Old 01-29-2012, 07:15 AM   #9
scf31's Avatar
1977 25' Caravanner
Jeffersonville , Kentucky
I work in the Aircraft refurbish department, We always install hardware/fasteners wet with primer when dissimilar metals are used. a rule of thumb.
Movie Stars and Film Crews come to Me from hundreds of miles enticed by My knowledge, My imagination,expertise, creativity and innovations!
scf31 is offline   Reply With Quote
Old 01-29-2012, 09:10 AM   #10
1980 31' Excella II
Ocean View , Delaware
What type of primer?
Sue
Disneysue925 is offline   Reply With Quote
Old 01-29-2012, 09:22 AM   #11
"Cloudsplitter"
Sue
Zinc-chromate or any one of the approved AS sealants.
Usually just a dab of acryl-r on the threads works for me
Old 01-29-2012, 10:09 AM   #12
Bob Thompson's Avatar
Corpus Christi , Texas
Images: 67
The common grades of stainless steel most of us have access to is Food Grade T304 and Marine Grade 316. There are many other grades, such as those used in medical implants, the above are the common ones. You want the Marine Grade 316 SS. I usually buy at West Marine.
So Long!
Bob Thompson is offline   Reply With Quote
Old 01-31-2012, 10:08 AM   #13
1974 27' Overlander
Twisp , Washington
Going with 316 stainless...
Thanks for all the responses. Bob, I didn't check prices at West Marine, but I was able to order them from McMaster-Carr for less than a penny apiece. I think I now have everything either here or on the way to wrap this part of the project up by the end of the week, early next week at the latest . Which is good, I'm heartily sick of playing with glass by now. Later.
Dave
Old 01-31-2012, 12:16 PM   #14
"Cloudsplitter"
Dave,
Got these from McM-C... also stainless....nice up-grade. K 300 series lockable
ID:	149961   Click image for larger version
Old 01-31-2012, 03:07 PM   #15
Aerowood's Avatar
1971 21' Globetrotter
Arvada , Colorado
Sue
Any good epoxy primer is the best
Old 01-31-2012, 09:43 PM   #16
Ag&Au's Avatar
Originally Posted by ROBERT CROSS View Post
Dave,
A coincidence
I have the same black and silver little master padlocks on my storage doors.
The new latches you bought are identical to the ones that came on my trailer.
Ken
Quick window question... daved20319 Windows & Screens 2 01-17-2012 04:44 PM
Steel / Aluminum wheel question polarlyse Wheels, Hubs & Bearings 12 05-29-2011 07:49 PM
1980 Caravelle axle question Seymour Axles 5 05-14-2011 08:28 PM
A question on selling awnings Airy Awnings 21 04-24-2011 10:37 AM
Blasphemous question woytovich General Repair Forum 15 04-09-2011 08:36 AM
