04-07-2013, 07:55 PM
1970 31' Sovereign
Durango
Screen Removal
On some of my screens, the little knob came right off but now I am having trouble getting the rest off. I went and bought different size hex screw driver thinking maybe there was something in there I needed to unscrew (didn't work), sprayed WD40 on it (didn't work)... I'm not strong enough to get them off but neither have the other 4 people that tried... I'm sure I must be missing an important clue. Any ideas?
04-07-2013, 08:50 PM
1978 Argosy Minuet 6.0 Metre
Wauwatosa
, Wisconsin
Best thing is to take a photo or 2 to show us exactly what you are referring to. Things can change with different years. PO's can chance things.
Unless someone with your same year and model has the answer with out a pix.
Judging a person does not define who they are, it defines who YOU are.
04-07-2013, 08:59 PM
1970 31' Sovereign
Durango
Ill take a picture tomorrow! Thanks!
04-08-2013, 05:36 AM
Normal
I don't know what your screens look like, but ours have the little knob that opens and closes and then are attached with velcro all the way around.
We just started at an edge and tried to pull one loose and discovered the velcro. Who knew?
Much easier to clean these and the windows once they were removed.
Maggie
04-08-2013, 09:44 AM
1970 31' Sovereign
Durango
So the first 2 pics is the know I want off... The 3rd is what it looks like when it is off... And the 4th is why it has to come off... Thanks for the responses! Hope to figure this out soon.
04-08-2013, 12:31 PM
Wauwatosa
, Wisconsin
I might be wrong but they sure look like a set screw that takes an Allen wrench. My handles are smaller buy have an Allen set screw. Some were a bear to crack loose. I found replacement handles at inlandrv.com so I drilled out the screw of a couple them.
04-08-2013, 12:58 PM
1970 31' Sovereign
Durango
Allen wrench is the hexagon correct? I bought one that had multiple sizes & the two that were close didn't fit... One too big... One too small. I don't see anything inside though... Like I do with the ones that lock the windows.
04-08-2013, 02:39 PM
1974 Argosy 28
Fresno/Clovis
Yep, mine takes an allen wrench. Maybe the allen screw hole is stripped?
Roger
05-02-2013, 08:57 AM
1973 Argosy 26
tallahassee
Did you ever figure this out?
I am having the same problem. The allen wrench set I have has one to small and one to big. I can't get the knobs off to remove the screens. Did you ever figure this out?
05-02-2013, 09:37 AM
1976 31' Sovereign
Oswego
screen removal
Try metric allen wrench Harbor Frt. has inexp. set
05-02-2013, 09:07 PM
1970 31' Sovereign
Durango
Still trying to figure it out... Will know by the end of this weekend & get back to you... Going to vintage trailer academy... Guessing someone there will know!
05-03-2013, 04:43 AM
1973 Argosy 26
tallahassee
Please let me know what you find out. I want to take the screens off to rescreen and paint the trim. BTW what is the vintage trailer academy? That sounds like a fun weekend.
05-03-2013, 05:53 AM
1981 31' Excella II
New Market
Its just a simple allen screw. It should take and english set but if these came from a non-US supplier they could be metric. There is no reason you can't cut the knob off and install a new one if worse comes to worse. I am sure someone has replacement knobs. mcmaster.com will have knobs that will fit but won't look the same.
Perry
05-10-2013, 08:36 PM
1970 31' Sovereign
Durango
So... it is just a simple allen screw... HOWEVER... it is NOT metric... which is what most places sale these days. It did work and my screens are now off! Vintage trailer academy is in Albuquerque NM once a year... very enlightening...
05-11-2013, 04:49 AM
1973 Argosy 26
tallahassee
Well...I ordered a metric allen wrench and am waiting for it to come in, but I tried my allen wrench set I had in the garage and none of them fit. Do you happen to know which one actually worked for you measurement wise? I am so frustrated I might just cut them off. I looked up the academy, it looks like fun. We might try it next year. Thanks for the help.
05-11-2013, 04:58 AM
1972 25' Tradewind
Hammond
, Louisiana
DON'T cut the knobs off. I promise it's a regular allen wrench. Not metric. It's storming out right now or I'd go out there to find the size for you.
Jane
05-11-2013, 07:24 AM
1972 25' Tradewind
Hammond
, Louisiana
Ok... storm has passed...
it's a 6/32 Craftsman allen wrench...
I double checked it and unscrewed mine just to be sure!
PERFECT FIT.
This should help.
05-11-2013, 07:27 AM
1972 25' Tradewind
Hammond
, Louisiana
I did squirt something in the little hole to loosen a few of the screws up. Not sure what my husband gave me to use. I'm guessing WD40 in the small can. I had to open up the window to get on the underside to see what I was doing ..
and caught the drips with a rag as I squirted and waited a bit.
05-11-2013, 03:42 PM
1970 31' Sovereign
Durango
It's actually an SAE Allen wrench... Not metric. Ill look it up when I get home
05-11-2013, 07:26 PM
1974 Argosy 26
Morrill
, Nebraska
I don't think it is a 6/32 Allen wrench. 6/32 is 3/16 and that is just shy of 1/4".
