Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Windows, Doors, Locks & Vents > Windows & Screens
Old 08-21-2011, 09:56 AM   #1
Gsnedike's Avatar
Phoenix , Maryland
Smile Screen for Bambi rear window
We have a 2006 Bambi and would like to hear from anyone who knows where I can get a screen for the rear window. On hot nights the increased circulation would be great. I know it is a escape window but I figure if I found or made a screen that could be attached with velcro it wouldn't impede a quick exit in an emergency. If such a screen exists I figured I would save the effort of making one.
Gsnedike is offline   Reply With Quote
Old 08-21-2011, 10:14 AM   #2
blmitch5's Avatar
2006 19' International CCD
Olathe , Kansas
We just use the roof vents with the fantastic fan running.
The only problem is you would have to use something to prop the window up. I'm sure someone will chime in that has done it but I'm leaving mine alone since the fan seems to do the trick.
Get involved and sign up for a Rally!
https://www.airforums.com/forums/calendar.php
WBCCI 4973
blmitch5 is offline   Reply With Quote
Old 08-21-2011, 10:27 AM   #3
SilverRanger's Avatar
2005 19' Safari
1968 24' Tradewind
Rural , Delaware
Here's a post about how I solved that problem for my 2005 Bambi. (Never mind the air conditioner). Just look at the second picture and you'll see the shroud I made out of a quarter inch sheet of plastic to cover the frame for the AC. I taped a sheet of wrapping paper over the window opening and traced the outline for cutting the hole. (If you can't find a sheet of plastic, Plexigalss or Lexan should work also.) This fits very nicely inside the existing groove in the window frame. What is not shown in the pictures is that I put a strip of Velcro around the inside edge of the shroud, to which I stick one half of those expandable screens that people put in their house windows for ventilation.
It doesn't need propping up because the window won't close all the way with the shroud in it. If I can find a picture, I'll post it later if you're interested. It really works out quite well getting cross ventilation across the bed, especially with the fan on.
http://www.airforums.com/forums/f42/...tml#post821583
2005 Bambi
1968 Trade Wind
2007 Ford F250 4x4 Crew
WDCU
SilverRanger is offline   Reply With Quote
Old 08-22-2011, 02:10 AM   #4
2005 19' Safari
GLENDALE , AZ
I recall reading that someone had this window fall off and break. I think this was an extremely odd occurrence, but I suspect that window costs about 3 or 4 times what most would think estimate. We have two FantasticFans, so we don't have any trouble moving enough air without opening the emergency hatch.
Old 08-22-2011, 06:58 PM   #5
2005 19' Safari
1968 24' Tradewind
Rural , Delaware
As soon as the rear vent disintegrates again (and it will), I plan to replace it with a Fantastic Fan with a 2 way fan. That does seem like better solution.
2005 Bambi
1968 Trade Wind
WDCU
Old 05-21-2015, 09:32 AM   #6
2008 19' Bambi
Houston , Texas
Hi, can you send me the pictures of your homemade screen and directions for making for the Bambi. I have two fantastic fans but still want the cross ventilation above my bed. Thanks for any assistance you can give me. Nancychristian2001@yahoo.com
Marmee is offline   Reply With Quote
Old 07-24-2015, 03:59 PM   #7
Wilma's Keeper
jackbickel's Avatar
2000 25' Safari
stow , Massachusetts
screen for rear window
We just posted a thread of how we made a screen this week for our rear window. It won't show up until approved by a reviewer, but I'll attach four pictures that show the approach. Good luck- our works well.
ID:	243813   Click image for larger version
ID:	243815   Click image for larger version
jackbickel is offline   Reply With Quote
Old 07-24-2015, 04:30 PM   #8
RangerJay's Avatar
2002 19' Bambi
Northwestern Ontario , - on the backside of the map and just above the big green spot
Images: 44
We also use a fantastic fan - but only on crazy hot nights - my wife is not a big "fan" of the noise or the volume of air being pushed/pulled around.
On the just plain hot nights we'll use one of those small desktop fans (8 inch or thereabouts?) - 2 speed - very quiet - set up on the dinette to bring in fresh air from open windows and blowing down the length of the trailer - all other windows/vents open as well and maybe even the door.
Jay
Bambi - 2002 (The Toaster)
Pathfinder - 2009 (The Buggy)
"I'm not young enough to know everything ....."
(Oscar Wilde)
RangerJay is offline   Reply With Quote
Old 07-24-2015, 06:26 PM   #9
remphoto's Avatar
2015 16' Sport
Upper Sandusky , Ohio
On our old SOB we just took a piece of fiberglass screening, put some velcro around the edge and used a stick to hold the emergency window open. Kind of jury-rigged and likely to get one banned at certain RV parks, but it worked. Probably will try one of the more elegant solutions for the AS.
2015 Airstream Bambi Sport 16J
Past Travel Trailers:
*1992 Dutchmen 30' Bunk
*2003 Jayco Designer Series 32' Rear Living
*2015 T@B Sofitel S (exchanged after 3 days for Bambi)
remphoto is offline   Reply With Quote
Rear window screen pass through-pet door triterra Windows & Screens 4 07-19-2011 07:43 PM
1969 Airstream Ambassador / Broken Rear Window pewalker1 Windows & Screens 0 07-05-2011 10:50 AM
Rear window leak fixed! Really? I think so. 1964 GlobeTrottin 1960 - 1964 Globetrotter 0 04-30-2011 05:42 AM
