Old 06-16-2015, 08:05 AM   #1
carver 1's Avatar
2011 30' Classic
2007 25' International CCD
1993 32' Excella
Largo , Florida
Images: 30
Screen door plexiglas panels
I thought I would share my answer to running the AC with the screen door open to provide light and a feeling of openness. I purchased the plexiglass @ Lowes where they cut to size. The only thing i had to do was trim the arches for the upper panel. This was accomplished on my belt sander after I traced the arch with the panel in place. I placed 8 Rivnuts in each panel to support the plexiglass. Since the Lowe's plexiglass was rather thin (this provides the flexibility to bend to the curvature of the panels) I luted small half moon pieces of thicker plexiglass. This supply's thickness to eliminate the movement and rattling of the panels. I used panel clips in the rivnuts to secure the panels in place. This makes for an easy way to remove and install the panels. I've attached several pictures of the project. Total time, about 2 hours. Thanks go to fellow Airstreamer and friend Larry O for his help and ideas.
>>ron<<
Name:	screen door panels (1).JPG
ID:	240778   Click image for larger version
Name:	screen door panels (2).JPG
Name:	screen door panels (3).JPG
ID:	240780   Click image for larger version
Name:	screen door panels (5).JPG
2015 GMC Denali 2500, 4x4, Duramax diesel, Topper, Pro Pride 3 P, Sendel 16" with Michelin LTs, one Yellow Labrador Retriever (AS security)
carver 1 is offline   Reply With Quote
Old 06-16-2015, 08:29 AM   #2
Kevin245's Avatar
Nice work! Looks great.
Eleanor Roosevelt
Old 06-16-2015, 08:34 AM   #3
AWCHIEF's Avatar
Biloxi , Mississippi
Images: 33
Brilliant project. Looks like it came from the factory that way.
MICHAEL
AWCHIEF is online now   Reply With Quote
Old 06-16-2015, 09:25 AM   #4
airdreamers's Avatar
2008 28' International
Venice , Florida
Images: 14
Ron, it will work like a charm! I used ours today finishing up the curtains Janice made, also a beautiful job. She says next time we will spent the $2000+-, too much work, beautiful.
BTW, Nice job yourself!
Bill and Janice, We're lovin' it! (Airstreaming)
Airdreamers
WBCCI #8880
AIR #41310
airdreamers is offline   Reply With Quote
Old 06-16-2015, 09:58 AM   #5
Al and Missy's Avatar
2002 30' Classic S/O
Melbourne Beach , Florida
That is a great looking project. I think I'll have to do it. I had to google "luted" but now I know what that means, and I knew what Rivnuts were, but I'm used to them being pressed and expanded into Aluminum with a hydraulic press. Google is your friend, I found the Rivnuts and installation tool online.
What panel clips did you use? Zooming in on your picture they look like the clips that Lowes and HF sell to hold window screens into window frames.
Al
Al, K5TAN and Missy, N4RGO
2002 Classic 30 Slideout
S/OS #004
Old 06-16-2015, 02:04 PM   #6
Rivet Puller
SeeMore's Avatar
2003 28' Safari S/O
Atlanta Burbs , Georgia
Hint, if you mount the screen clips tab side down (opposite instructions) there is no need to lute. You can also mount the plexi inside the screen so you easily remove the panels for those seasons when you want the fresh air. 1/8" plexi fits perfectly; project time = 1 hour.
SeeMore is offline   Reply With Quote
Old 06-16-2015, 02:28 PM   #7
1987 Avion 34W owner
PaulnGina's Avatar
Good Ol' , USA
That project is a great idea. Thank you!!!
Whats good for me may not be good for the weak minded.
1987 Avion 34W
1995 Ford F250 7.3L PowerStroke
PaulnGina is offline   Reply With Quote
Old 06-16-2015, 08:19 PM   #8
WBCCI # 23456
2000 30' Excella
Greeneville , Tennessee
Yep, done it. Works great.
jimfa440 is offline   Reply With Quote
Old 06-16-2015, 08:30 PM   #9
carver 1's Avatar
2011 30' Classic
1993 32' Excella
Largo , Florida
Images: 30
Al
I got the panel clips at ACE Hardware.
>>ron<<
Old 06-16-2015, 08:37 PM   #10
carver 1's Avatar
2011 30' Classic
1993 32' Excella
Largo , Florida
Images: 30
In my mind, one of the advantages of the .080 plexi is that it is very light and puts less strain on the Aluminum hinges that support the screen door. Use of the screen clips provides a very easy approach to taking the panels off and on. The Admiral made a cover for the panels(something that resembles a pillow case) and we can store the panels behind the couch when not in use.
>>ron<<
Old 06-16-2015, 09:15 PM   #11
richinny's Avatar
2011 34' Classic
i put my panels on the outside. if it rains without the awning out, it is less likely to drip inside because of the curve of the trailer and door.
Ricky
Windows or plexiglas ? Gal Windows & Screens 44 06-30-2016 12:58 PM
Panels for Screen Door to allow open with AC on To Gulls Windows, Doors, Locks & Vents 8 06-12-2015 06:28 PM
pitch on plexiglas rock guard Orson Windows, Doors, Locks & Vents 5 09-29-2012 10:50 AM
Front Window Plexiglas Guard Replacement boltos Rock Guards, Segment & Window Protectors 29 08-25-2009 06:00 PM
Plexiglas Door Hinges jglabrown Cabinets, Counter Tops & Furnishings 3 08-10-2009 06:45 PM
