Old 10-17-2011, 12:14 PM   #1
Safari 2005 Window Crank Failure
On my rear side windows the bottom third of each window cranks out by turning a 3” round crank knob. On both windows the knob will easily crank until the window initially pops out ½” and then the crank knob totally freezes. From the outside I can pull on the window easily opening it to full extension but it reverts to its initial ½” pop-open spot because the springs are still functioning.
At this point I can close the windows using the crank knob with no problem.
Any ideas why the crank knob freezes?
How can I remove the inside screen so I can investigate further.
Neil Ervin
neil.ervin is offline   Reply With Quote
Old 10-23-2011, 09:51 PM   #2
Posting pictures..
Name:	Airstream Window 1 d111001.jpg
ID:	143555   Click image for larger version
Name:	Airstream Window 2 D111001.jpg
Neil Ervin
Old 10-23-2011, 11:31 PM   #3
ROBERTSUNRUS's Avatar
Salem , Oregon
Images: 18
Hi, I haven't had that problem with mine; Possibly the the gear mechanism is stripped.
2005 Safari 25-B
"Le Petit Chateau Argent"
[ Small Silver Castle ]
YAMAHA 2400 / AIR #12144
Old 10-24-2011, 06:37 AM   #4
jdalrymple's Avatar
2009 27' FB Flying Cloud
1991 35' Airstream 350
Jay , Oklahoma
Perhaps spray a little silicon into the mechanism, and have someone turn the knob while you lift the glass gently. That might free it up.
Jeff & Cindy
'09 27FB Flying Cloud
'91 350 LE MH
Broken window in our Safari. Betty & Jim Windows & Screens 17 03-29-2014 02:46 PM
Tinbad :: 2005 A.S. Safari Del Gurney Airstream Registry Discussions 0 08-19-2011 08:32 AM
Mary Joan :: 2005 Airstream Safari SS wrochdvm Airstream Registry Discussions 0 08-19-2011 08:31 AM
TinShack :: 2005 Airstream Safari TinShack Airstream Registry Discussions 0 08-19-2011 08:31 AM
Trailer Hitch for 2005 25' Safari basecamp1 Hitches, Couplers & Balls 7 03-28-2011 07:40 PM
