Old 02-26-2005, 07:35 AM   #1
1983 27' Excella
French Settlement , Louisiana
Unhappy Rockguards
Why do I not see rock guards on the newer trailers.Does the new glass not break ?HA-HA' wright Am I missing something or what I only see them on the older trailers. Or am I missing them and do not realise it Billy
housebg is offline   Reply With Quote
Old 02-26-2005, 08:11 AM   #2
2003 25' Safari
Eden Prairie , Minnesota
Dark tinted Plexiglass rock guards cover the front window on all new Airstreams. Look closely at the photos on Airsteam's web site: http://www.airstream.com/product_lin...ssic_home.html
Dan
dmac is offline   Reply With Quote
Old 02-26-2005, 01:35 PM   #3
1983 27' Excella
Exclamation rockguard
how do these attach I have a 1983 Exella I see no holes was this standard or an option.I am learning owning a airstream is a lot like being married you can never explain it to any one .
Old 02-27-2005, 07:07 AM   #4
balrgn's Avatar
1974 27' Overlander
1954 26' Romany Cruiser
1960 26' Overlander
Rockingham County , New Hampshire
Images: 74
Send a message via AIM to balrgn Send a message via Yahoo to balrgn
Check out this string. For my '75 it wraps around the windows all in one piece.
http://www.airforums.com/forum...ad.php?t=15315
'74 Overlander (T-O-Bee)
'46 Spartan Manor (Rosie)
'54 Cruiser (Bogart)
'60 Overlander (Hoagy)
WBCCI 1754 - AIR # 6281
www.balrgn.com
balrgn is offline   Reply With Quote
Old 02-27-2005, 11:08 AM   #5
1983 27' Excella
rockguard
On my trailer the front window wraps around the front of the trailer.would it be one piecesor three.I guess I was thinking about old rockguards that had a frame and look like coragated roofing.
Old 02-27-2005, 11:29 AM   #6
Moderator Emeritus
overlander64's Avatar
1964 26' Overlander
1978 Argosy Minuet 6.0 Metre
Anna , Illinois
Images: 183
Rockguards
Greetings Billy!
The deep-wrap wing windows that were pioneered on the 1970s Argosy coaches are typically fitted with the three-piece deep-wrap rock guard. The side wings are attached with a lift-off-hinge arrangement with set-screw locking devices, and the center section is hinged at the top to open with adjustable side support arms. While the rock guards are a standard feature on the late model coaches, there was a time when they were optional equipment (this was true on all Argosy trailers pre-1980) and it seems that the rock guards were also an option for a time after the deep-wrap wing windows were introduced on the Airstream coaches. An installed example of the three-piece guard can be seen in the photo of my '78 Minuet (the center section is not standard as it had to be narrowed more than 1/2 foot to fit the narrower Minuet) -- I have also attached a photo that shows the deep-wrap wing window before the rock guard installation. Someithing to consider is that the only replacements for the deep-wrap wing windows are the later model deep-tinted style that may not be ideal if your coach happens to have non-tinted original wing-windows as my Minuet does - - this was a big factor in my decision to have the rock guard installed (along with the high cost of having replacement wing windows installed).
Good luck with your research!
Kevin
Name:	Minuet Rock Guard_1978.jpg
ID:	10623   Click image for larger version
Name:	1978 Minuet front_streetside_corner-med.jpg
Kevin D. Allen
AIR #827
Old 02-27-2005, 12:16 PM   #7
balrgn's Avatar
1974 27' Overlander
1960 26' Overlander
Images: 74
Not sure how far your windows wrap around. On our '75 they do not go back to the side. If you windows wrap further you'll need one of the new styles....
Name:	75 Trade Wind.jpg
www.balrgn.com
Minuet Front Window Rock Guards overlander64 All Argosy Trailers 54 12-01-2003 09:13 PM
Rockguard tmeagle1 Rock Guards, Segment & Window Protectors 12 04-02-2003 07:59 AM
Alaska PeterH-Airstreamer On The Road... 11 09-04-2002 07:57 AM
'66 Safari - step and window guard parts? Gordon 1966 - 1968 Safari 1 04-20-2002 11:16 AM
