Old 10-22-2019, 05:22 PM   #1
2017 16' Sport
Canyon Country , California
Rock Guard Shield over glasses does not fit snuggly on Airstream
While washing my7 Bambi I noticed that the Dark Rock Guard Shield does not fit perfectly on my Bambi. I could see the rubber seal but it does not touch the Airstream. Is it wrong shield on the Bambi? I had to open both to clean out the leaves or pine needles.
I didn't take pictures because I was trying to finish washing and waxing.
2014 Ford Explorer XLT with factory installed Tow Package.
2017 M16 Bambi
Halford1 is offline   Reply With Quote
Old 10-22-2019, 05:30 PM   #2
2015 23' FB International
2007 19' International CCD
Steamboat Springs , Colorado
I have the same condition on both the 19' Bambi and the 23FB. The cover acts like sunglasses protecting the wrap-around windows mounted on the body. Not meant to be sealed.
Steamy1 is offline   Reply With Quote
Old 10-22-2019, 05:30 PM   #3
2007 22' International CCD
Apparently not unusual. Mine has huge gaps when parked as well. Stuff falls through, usually.
Old 10-22-2019, 06:00 PM   #4
2017 16' Sport
ok good to know then what is the purpose of the rubber seal?
2017 M16 Bambi
Old 10-22-2019, 06:04 PM   #5
My theory is itís there to avoid scuffing the aluminum. Wind may mash it back onto the skin when the Airstream is being towed at highway speeds.
Old 10-23-2019, 10:38 AM   #6
Watertown , Massachusetts
Interesting theory, but I don't think the lock mountings would allow that unless they gave way altogether. And in that case you would be dealing with wildly flopping shields.
My theory is - poor design.
sallye is offline   Reply With Quote
Old 10-23-2019, 10:40 AM   #7
Silver Star
rucos's Avatar
1970 23' Safari
Victoria , British Columbia
Good question .... Ive often wondered as mine sits out too?? Rubber seal seems kind of useless .
rucos is offline   Reply With Quote
Old 10-23-2019, 10:58 AM   #8
Married with Airstream
drbrick's Avatar
2004 25' International CCD
Vancouver Island , British Columbia
I have yet to see one that fits tight. IMHO the "seal" is not really a seal per se but rather a buff strip to keep the rock sheild from touching the alum exterior.
La Dolce Vita Brick & Mona
2004 International 25CCD Registered Name "Blue Streak"
2013 F-150HD SuperCrew FX4 Lariart (MaxTow) "Red Dragon"
Married With Airstream Blog Click Here
Blog Languages: English/French/Spanish
drbrick is offline   Reply With Quote
Old 10-23-2019, 11:50 AM   #9
thewarden's Avatar
2016 27' International
Sherwood Park , Alberta
I have concluded that the rubber seals are there to catch and collect as many leaves, pine needles and dirt as possible. That way you have something to do at the campsite when you are bored and having nothing better to do.
thewarden is offline   Reply With Quote
Old 10-23-2019, 12:06 PM   #10
Silver Goose's Avatar
2008 27' Classic FB
Burkburnett , Texas
Thick gasket, big gap
Iíve wondered if they were designed for an earlier model with a different radius. While they remain functional in protecting the glass from flying stones, etc., it does seem that for such a pricy trailer the gasket would fit closely enough to keep out the leaves and twigs that fall in the gap.
Silver Goose is offline   Reply With Quote
Old 10-23-2019, 12:32 PM   #11
Foiled Again's Avatar
2012 25' FB Eddie Bauer
Virginia Beach , Virginia
Pool noodles to the rescue... again.
Get a bright colored pool noodle and slice it open. Cut to length of curved glass and install over.the cirved segment protector.
It will keep out.all the leaves, etc. Use only while parked, remove when underway or it may scratch the trailer.
Of course this same thing works on awning arms to protect against head bonks.
Old 10-23-2019, 01:17 PM   #12
abqdor's Avatar
2016 25' Flying Cloud
Albuquerque , New Mexico
Same issue as everyone has mentioned about debris getting behind the curved rock guards. No need to go the pool noodle route. Get yourself some 1/2-inch foam pipe insulation which is already pre-cut. You'll have to experiment with whether or not you want to remove the yellow sticky tape covering at the seam. I've tried it both ways.
'17 Ford F-150 Ecoboost, max tow package
'13 GMC Yukon Denali 6.2L V8
'04 GMC Yukon SLT 5.3L V8
abqdor is offline   Reply With Quote
Old 10-23-2019, 01:28 PM   #13
1976 31' Sovereign
Oswego , Illinois
The plastic rock guard can be bent {tweaked} to fit against body but use caution when doing so to not kink frame. IMO leave it alone.
Old 10-23-2019, 01:45 PM   #14
2019 25' International
Providence , Rhode Island
I was told specifically that it isn't meant to hug/seal the window. Mine is similar.
kittmaster is offline   Reply With Quote
Old 10-28-2019, 02:50 PM   #15
2017 16' Sport
Good idea! I will go to Lowe's and get like 4 foam pipe insulations. I am in an area where pine straws, leaves and dust would get in there. Just want to prevent leaves from going in between the glasses. thanks foiled again and abdogor for the great idea!
2017 M16 Bambi
Old 10-28-2019, 04:12 PM   #16
picking up on this idea; how about using foam pipe insulation and placing on the inside just under the rubber, then closing to compress the foam between the inner and outer glass? I am going to try this and see how it works.
Old 10-28-2019, 10:07 PM   #17
2017 16' Sport
yea lets try that and see if it does not fall out or inside...
2017 M16 Bambi
Old 10-30-2019, 05:26 PM   #18
2002 34' Classic S/O
sault sainte marie , Michigan
If it is not a design goal (the leaf storage), it does turn out to be a feature, for sure. I say, if the sunglasses cannot be sealed completely, they at least need to be vented (by the gaps and imperfect fit against the trailer body) in order to slow the growth of mildew, which seems to happen plenty quickly anyway despite the imperfect fit.
bartzstream2 is offline   Reply With Quote
Old 10-30-2019, 06:55 PM   #19
2017 16' Sport
That's true for areas with high humidity. We do get occasionally (not enough) rain in California but its so darn dry. We do have mildew in California where there's constant wetness in the dark like shower, in walls where pipes leak and etc. I have lived in the South where mildew are everywhere but in California, its harder to find mildew where there's a lot of light.
2017 M16 Bambi
Old 10-30-2019, 07:25 PM   #20
overlander63's Avatar
1993 21' Sovereign
Colfax , North Carolina
The rubber gaskets are there to prevent the extrusions on the rock guards from scratching or otherwise damaging the window frames and sashes of the trailer, and to keep the metal from rattling/making noise from rubbing on or striking the window areas.
Rock guard fixed itself. We bought new RS rock guard, waiting for delivery, went to Garymaya Rock Guards, Segment & Window Protectors 1 09-20-2017 04:00 PM
Front Window Rock Guard Fit jreckin Windows & Screens 1 04-24-2016 01:42 PM
Will the 3-piece rock guard from an 83 Excella Fit My 76 Arogsy? AndyPenny Rock Guards, Segment & Window Protectors 12 05-16-2008 09:57 PM
How snug is a Rock Guard supposed to fit? I BEgan Windows & Screens 2 04-13-2008 05:24 PM
