Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Windows, Doors, Locks & Vents > Windows & Screens
Prev Previous Post   Next Post Next
Old 08-08-2009, 06:27 PM   #1
Minno's Avatar
Profile:  1972 31' Sovereign
Lexington , Minnesota
Rivets around windows
I have removed 2 Vista View windows, and both wing windows on Little Girl. One of the vista views is already re-installed without any issues. My question invloves the other 3 windows.
The 2 vista views and the right-hand wing windows were replaced at some point. The left-hand wing window is original, although it's missing the front pane of glass (which is why I took it out). When I removed these 3 windows, each of them has a 3 to 4 inch section on one of the round corners where the rivets on the window do not go into the trailer skin. It looks like the openings were all cut a tad too large. The edge of the window coveres the opening ok, but there are 5 or 6 rivets in a row than do not attach the window frame to anything on the trailer.
I thought when I discovered this oddity on the replaced vista view and wing windows, that it was just part of the shoddy job they did during the replacement (like the regular steel pop rivets they used). But, when I discoverd the same thing on the original wing window, it got me wondering if others have come across this during window replacements.
I was thinking about cutting a strip of aluminum about 1 to 1 1/2 inches wide and using it as a backer for the sections where the rivets do not attach to the skins. My thoughts were this extra piece of aluminum would help act as a clamp and more firmly attach the winodws to the skin all the way around.
Does that sound sensible? Or am I being too concerned about a normal assembly oddity of airstream windows?
Chris
btw - We found two things that remove old vulkum fairly easily. One is Gumout carb cleaner, and the other is Pro Strength "De-Solv-it" - we found it at Ace Hardware. The De-solv-it works on silicone and other caulks as well, and does not discolor the alumimum.
Buck rivets or Olympic rivets? Sparkygus Ribs, Skins & Rivets 20 02-28-2009 09:33 AM
Lousy Rivets!/Weak rivets sunk the Titantic? 1956Safari Off Topic Forum 14 04-18-2008 02:35 PM
Olympic Shaved Rivets vs. Buck Rivets with Dimple msjaarda Ribs, Skins & Rivets 8 03-16-2007 11:00 PM
Windows-probs, Linux more prbs...back to Windows Kistler Off Topic Forum 13 11-04-2004 10:19 AM
