Originally Posted by Deairstream I have a recently purchased 1993 Excella. I just washed it went in the AS and found water was inside the front. It appears that the water came in from the top of the window. It is aonly on one side of the panoramic windows. I inspect the window and discover that the PO silicon the inside of it. The AS has rock guard panels and a 3 piece panornamic rock guard for the window. The leakis coming from the top closest to the center panel. Can it be the hinges of the center rock guard or do I have to replace the windows. The way the windows are installed makes me think the source of the leak is not at the window but could be above or where the hinges for the rockguard are attached. Any suggestions would be greatly appreciated. |
Seal the entire "wrap windows" with Parbond, on the outside of the metal frame (sash).
Seal the gasket that's between the glass and metal frame, with a small bead of vulkem sealer, so that the sealer is ever so slightly on the glass and sash.
You should do that on both wrap windows.
You might also remove the center section of the 3 piece rockguard, and reseal the hinge with the vulkem sealer.
Hopefully there is no silicone sealer on the outside. If there is, then every trace of it must be removed. If not, the new sealers will not properly bond.
If you still have a leak, remove the clearance lights and seal those as well.
