Old 09-08-2012, 05:25 PM   #1
1971 18' Caravel
powder springs , Georgia
Restoring the Screens in my '71 Caravel
I'm wondering if anyone has had luck locating the brush like material that is fitted to the back side of the screen frame that acts as a barrier to insects and weather? Its that fuzzy stuff the lever control arms, used to manipulate the windows open and closed, slide along.
bobmstein is offline   Reply With Quote
Old 09-08-2012, 06:00 PM   #2
Minno's Avatar
1972 31' Sovereign
Lexington , Minnesota
We bought new at either Out of Doors Mart or Vintage Trailer - I forget which one. We tried buying the ones that come all together, and you just pop in but they didn't fit in our '72 sovereign. You hot glue the fuzzy stuff in - goes pretty easily.
Kay
Old 09-09-2012, 06:36 AM   #3
1971 18' Caravel
Thanks I'll try those two sources and go from there.
Old 09-09-2012, 06:38 AM   #4
Melody Ranch's Avatar
1956 22' Flying Cloud
1953 32' Liner
1955 22' Safari
Valley View , Texas
Images: 78
Inland has it.
Old 10-16-2012, 06:19 PM   #5
DryFly's Avatar
1972 Argosy 20
Snoqualmie , Washington
What's it called?
DryFly is offline   Reply With Quote
Old 10-17-2012, 06:32 AM   #6
Minno's Avatar
1972 31' Sovereign
Fuzzy Seal for windows. Seriously, that's its name.
Old 01-24-2013, 07:36 AM   #7
1977 27' Overlander
Portsmouth , New Hampshire
I bought the Fuzzy seal and glue at Oasis RV in Tuscon, AZ
sailaw is offline   Reply With Quote
caravel
1966 Caravel - barebones from factory? - restoration brusby 1966-68 Caravel 55 04-12-2012 06:49 AM
Caravel :: 1967 Airstream Caravel youngestmeyn Airstream Registry Discussions 0 11-29-2011 09:31 AM
Caravel :: 1967 Airstream Caravel C Johnson Airstream Registry Discussions 0 08-19-2011 08:31 AM
67 Caravel Help: to sway or not to sway vonzellen Hitches, Couplers & Balls 15 01-26-2011 05:07 PM
