Old 10-24-2011, 12:27 PM   #1
1970 31' Sovereign
cumberland , Maryland
Resealing exterior Vista windows question
Have a leaky vista view window on my 70 sovereign and i think that exterior reasealing should do the trick. I've read some threads on here for restoration of the vista view windows but just need clarification on a couple of things. Should all of the old exterior caulking be removed before application of caulking?, AND what is best cauking to use for this application? durabond or vulkem ?Should it be spread smooth to bond or just left ridged, also its getting cold and I'm concerned about setup. Would I be best to just cover with plastic and tape and wait till warm weather? thanks
travalota is offline   Reply With Quote
Old 10-24-2011, 04:17 PM   #2
Flynavy's Avatar
1974 25' Tradewind
Col. Station , Ohio
I am not sure how much sucess you will have without completely removing the glass, cleaning it up and reset in vulkum, but I guess you have nothing to lose, so give it a try. I would dig out as much of the old seal as you can, clean it with mineral spirits, denatured alcahol, and seal with the vulcum. I think you need temps above 50.
Flynavy is offline   Reply With Quote
Old 10-24-2011, 04:22 PM   #3
Aerowood's Avatar
1971 21' Globetrotter
Arvada , Colorado
Is the leak from around the frame to trailer body or is it frame to glass?
Old 10-27-2011, 08:22 AM   #4
Clean the surfaces very well, then apply Vulkem or Sikoflex sealer.
Newbie Question Kd9 2011 - 2015 International 57 09-14-2015 07:08 PM
NEEDED: Two front windows for '71 Overlander jesse_kevon Windows, Doors, Locks & Vents 4 05-30-2015 09:26 AM
Double Pane Windows perryg114 Windows & Screens 4 09-12-2011 04:30 PM
Blasphemous question woytovich General Repair Forum 15 04-09-2011 08:36 AM
'73 Tradewind Windows Vista and Front Sides constructor Windows & Screens 8 01-28-2011 05:44 AM
