Old 11-26-2008, 06:29 AM   #1
1967 26' Overlander
Salford , Lancashire
Replacing Windows on our '67
Hi Guys new here but could really do with some advice as to where I might find replacement windows for my '67 Overlander. Or alternatively would it be better to have the -curved - windows remade in Perspex by a local fabricator.
I'm based in Manchester, England.
Redbutton is offline   Reply With Quote
Old 11-26-2008, 07:04 AM   #2
Lumatic's Avatar
1993 34' Excella
Estancia , New Mexico
Images: 16
Perspex huh? When I saw that I knew you one of those rare Limey Streamers. I suppose your car also has a bonnet and a boot instead of a hood and trunk like God meant it to have.
If I got this right Perspex is what we here in the colonies call Plexiglass. Lexan is greatly superior to Plexiglass, but I don't have a clue what yu blokes call it. It is a polycarbonate plastic. Plexiglass likes to crack over time. Both are susceptable to the effects of UV light but plexi is far worse. Lexan tends to discolor over a period of years. Lexan is also more flexible, and more expensive.
Old 11-26-2008, 07:20 AM   #3
goransons's Avatar
1963 22' Safari
1955 26' Cruiser Overlander
Yakima Valley , Washington
Send a message via MSN to goransons
The glass isn't that bad in price. I bought one of the large (like 39" long) curved windows and had it shipped for less than 200 bucks through Inlandrv.com. Vintage Trailer supply has them too, a little more expensive but has a warranty on them (not sure if inland does or not, didn't ask). Of course your shipping would be more. Did this about 2 weeks ago on our 66 overlander. www.inlandrv.com and www.vintagetrailersupply.com are the websites.
Install was really easy. Came with a drill bit that I ran down the track to clean out the debris from years of adhesive etc. Also took a little metal out because the new glass is ever-so-slightly thicker. I removed the track, used Vuelkem to install the track to the glass, let it set up for a day then reinstalled the track, new weatherstrip was included and it was all done.
Personally I like the look of real glass myself, but both plastic and glass have their positives and negatives.
good luck!
goransons is offline   Reply With Quote
Old 11-26-2008, 07:26 AM   #4
modarch's Avatar
1967 17' Caravel
Thompsons Station , Tennessee
I second gorasons' comment. Go with the glass. I replaced 3 of the 5 windows w/ glass from Inland. It is pretty easy. It looks great and closes tight. The plexi from the PO leaked pretty bad b/c it didn't seal tight.
modarch is offline   Reply With Quote
Old 01-28-2009, 11:32 AM   #5
1967 20' Globetrotter
1967 24' Tradewind
Manteca , California
I think I have the windows you need off a 67 tradewind. total window frame if needed. Shipping to you from California may be a deal killer, but if you are interested let me know. Give specifics on window sizes. Rex
RexSides is offline   Reply With Quote
Old 01-28-2009, 12:18 PM   #6
silverleeper's Avatar
1967 22' Safari
1960 Caravel
Edmonds , Washington
Images: 8
Hi Redbutton, Once you found your windows this will help. Install instructions. Don't go with plastic. VTS or Terry at Inland RV can help you with the glass replacements.
Name:	Airstream manual 86.jpg
ID:	74754   Click image for larger version
Name:	Airstream manual 87.jpg
Lee
1973 F-250 4X4 390
1965 Chevy Suburban 454
AIR 6030
WBCCI 4258
TCT
silverleeper is offline   Reply With Quote
Old 01-28-2009, 02:02 PM   #7
BIGED52's Avatar
1967 22' Safari
MILAN , Illinois
Redbutton, You will be better off over the long run to use real glass replacement windows in your trailer. Use the search function tab on the blue tool bar above the thread. Search replacement for curved Corning glass. There are several threads that deal with window glass replacement but the glass on the 66' to '68 trailers wasn't even available until a few years ago. You will also need the gasket (seal) for around the window frames to keep the water out. You can now purchase the new style "D" gasket from Airstream dealers that replaces the original rubber gasket. Ask if you need any more info on this topic. Ed
Oh yeah, Welcome to the forums!!!!
1967 Safari Twin "Landshark" w/International trim package
1999 GMC Sierra 1500 SLT
FORUMS MEMBER SINCE 12/16/2004AIR#7110
"My tire was thumping, I thought it was flat. When I looked at the tire, I noticed your CAT!" Burma Shave
BIGED52 is offline   Reply With Quote
Old 03-01-2009, 09:45 AM   #8
1969 27' Overlander
Ehrhardt , South Carolina
Hello
I just aquired a 1969 overland 27 and broke the 2 front winged curved windows. I tried the 2 sourses listed here and my year isnt available.
Any ideas where I can get the replacement windows??
Dave
oldcar29 is offline   Reply With Quote
Old 03-01-2009, 09:55 AM   #9
goransons's Avatar
1963 22' Safari
Inland Rv has them, not on their website though. Out of doors mart shows them on their website, but the photo at the top is actually a 70 window. The photo below the description shows the correct window. Here's a link to one of the two sides:
Wing Window for 69 Airstream Road Side 680190 [680190] - $425.00 : ODMRV , Out-of-Doors Mart
and the other
Wing Window for 69 Airstream Curb Side 680190-01 [680190-01] - $425.00 : ODMRV , Out-of-Doors Mart
I'd check prices with your local airstream dealer, www.inlandrv.com and places like outofdoorsmart and see who comes out cheaper with shipping etc.
I'd definately invest in a rock guard, we too have a bad wing window on our 69 that will need to be replaced, cracked by the previous owner. Luckily hasn't leaked and we have one of those nice airstream tinted rock guards.
Scott & Megan
VAC LIBRARIAN
Restoring Wally Byam's 1955 26' European Caravan Trailer!
WBCCI 8671
1963 Safari from the 1963-64 Around the World Caravan
Old 03-01-2009, 10:36 AM   #10
Originally Posted by oldcar29 View Post
Hello
Dave
Check your other post about glass.
Replacing Front and Side Wing Windows monocoque Windows & Screens 5 03-17-2008 11:49 AM
Wondering what kind of glass to use for replacing all windows in 1958 Traveller williamhenshall Windows & Screens 3 08-19-2007 07:15 PM
Need Advice: Re-Sealing Windows & Replacing Table SueH Member Introductions 6 11-30-2006 03:35 AM
Replacing the curved windows in the Argy Chopper Windows & Screens 5 09-21-2006 02:40 PM
Replacing Windows larrylisa Windows & Screens 9 01-30-2003 03:50 PM
