Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Windows, Doors, Locks & Vents > Windows & Screens
Old 07-01-2010, 07:24 AM   #1
1961 16' Bambi
Jacksonville , Florida
replacing windows - glass, lexan, tempered glass?
The glass is missing in the front window of my newly purchased '61 Bambi and the back window is hazy plexiglass. The windows are flat and rectangular - no special curves or shapes. I have searched the forums and found recommendations for regular glass, lexan, and tempered glass for replacing windows. What are the pros and cons for each type?
BrianY is offline   Reply With Quote
Old 07-01-2010, 08:07 AM   #2
goransons's Avatar
1963 22' Safari
2020 27' Globetrotter
State of , Washington
Send a message via MSN to goransons
front windows have a lot of pressure on them, lexan will flex, or blow out... go with glass of some kind....
Scott & Megan
VAC LIBRARIAN WBCCI 8671
1963 Safari from the 1963-64 Around the World Caravan
goransons is offline   Reply With Quote
Old 07-01-2010, 08:15 AM   #3
purman's Avatar
1968 28' Ambassador
Cedaredge , Colorado
Glass is probably the best all around. If you don't have a rock guard to cover the front window Plexiglass is a good choice as it won't brake if a rock hits it. Well most of the time.
Jason
2008 5.7 L V8 Sequoia
AIR # 31243
WBCCI # 6987
FOUR CORNERS UNIT
Old 07-01-2010, 09:36 AM   #4
Wise Elder
Jammer's Avatar
2010 30' Classic
There are a couple of places on the internet that will make tempered glass of any shape, size, and specification and send it to you for a reasonable price, either with a DOT safety brand or without as you wish. That's what I'd do.
Old 07-01-2010, 12:08 PM   #5
1961 16' Bambi
Thanks for the replies. I think that I will go with tempered glass. Are there any problems using tempered glass on windows that open and close? I also need to replace some of the jalousie windows on the door - any problems with tempered glass there?
Thickness of Window Glass/Lexan Pschoerrn Windows & Screens 15 10-28-2009 05:12 PM
Wondering what kind of glass to use for replacing all windows in 1958 Traveller williamhenshall Windows & Screens 3 08-19-2007 07:15 PM
66-67-68 tempered glass. Inland RV Center, In Commercial Listings 8 10-20-2006 01:24 PM
Anyone know if Tempered Glass was used? Frostyone Windows & Screens 2 06-03-2006 04:05 AM
29" curved tempered glass window... and a warning! 67caravel Windows & Screens 12 08-22-2003 07:00 AM
