Old 09-28-2011, 11:43 AM   #1
2007 28' Safari SE
S , Texas
Replacing windows
We have to replace our rear (fire escape) window and a window on the driver side of our 28 foot, 2007 Safari. I now understand that in addition to the window glass being replaced, the frame actually has to be removed and replace because the frame and the window are one unit. Can anyone tell me the best & Cheapest place in Texas to get this done would be? We also have a friend in the construction business (of houses). Is this something he could do? Or is it clearly an "Airstream thing"? Thanks so much for your input. It is very appreciated.
RICH&JAN is offline   Reply With Quote
Old 09-28-2011, 01:54 PM   #2
Are they opening windows, or riveted to the shell windows?
Old 09-28-2011, 03:08 PM   #3
airstream4's Avatar
1997 34' Limited
1963 22' Safari
Troy , Michigan
Smile
I would hope a fire escape window opens!
Paul
Troy, MI
1963 22'Safari
1997 34' Classic FK
airstream4 is offline   Reply With Quote
Old 09-28-2011, 05:39 PM   #4
Well Preserved
1993 21' Sovereign
Colfax , North Carolina
The Safari window assemblies are really easy to change. If you look at the frame, you'll see a bunch of screws on the inside, simply remove the screws, the inner frame will pretty much fall out, and you can gently push the remaining part of the window out of the hole.
Just make sure you have the replacement windows in hand before removing the old ones, to make sure they are the same.
Old 09-29-2011, 07:10 AM   #5
2007 28' Safari SE
S , Texas
They are both windows that open. Thank you guys for your help!
Old 09-29-2011, 10:29 AM   #6
No riveting needs to be done to change out your windows.
Each of your 2 windows takes less than 5 minutes to install.
Old 09-29-2011, 07:08 PM   #7
2007 28' Safari SE
S , Texas
Awesome! Thanks again! That good to hear.
NEEDED: Two front windows for '71 Overlander jesse_kevon Windows, Doors, Locks & Vents 4 05-30-2015 09:26 AM
Double Pane Windows perryg114 Windows & Screens 4 09-12-2011 04:30 PM
Can windows be made? lucymcdog Windows & Screens 22 07-29-2011 03:40 PM
How do I know which windows I have? Roothawg Vintage Kin 4 06-12-2011 09:37 AM
'73 Tradewind Windows Vista and Front Sides constructor Windows & Screens 8 01-28-2011 05:44 AM
