12-21-2009, 11:28 AM
1974 27' Overlander
full time in canada/US
, British Columbia
Replacing Window Screens
I'm sure this thread has been answered but somehow i'm not finding it in perusing through the threads. Probably because i'm not sure what the right terminology is!
I'm looking to find a source for the rubber tubing that holds my 1974 Overlander's window screens in place. I was able to replace the door screen with regular tubing from a hardware store, but the tubing for the windows is much thinner. (picture showing the screen tubing)
Does anyone know of a good online source (and maybe the propper terminology for said tubing?!)
Kim
12-21-2009, 11:38 AM
When I did the screens on my GlobeTrotter I was able to use the standard size for all but the screen door. For the screen door I went to Lowes and found that they had a 0.125" (1/8in) diameter spline that worked like a champ.
12-21-2009, 11:42 AM
Corona
Kim
Home Depot has that "spline".
12-21-2009, 01:40 PM
Power to the People !
1972 31' Sovereign
SAN DIMAS
We got ours at Lowes. If possible re-use the old spline, if it's still in decent shape. The other option is using the smallest spline mention in the other posts and pulling/stretching it as you go. This will help get it in the groove. That's how we did it.
Mary
12-21-2009, 02:47 PM
Iwannagocamping
Rineyville
, Kentucky
any decent hardware store will have it, it's called "spline" and comes in different sizes. I *think* you need 1/8th. You would think I could remember, just did all our windows a couple months ago..
See our blog here on how two RV/AS rookies tackle a 1979 Sovereign resto!!
Just the photos.. (sometimes you don't need the blog, just a picture worth a thousand words..)
1979 Sovereign International
2004 Ford Expedition Eddie Bauer
2 Golden Retrievers
Air # 36788
TAC# 3179
WBCCI # 1265
12-21-2009, 02:57 PM
Corona
Kim
Kim.
When replacing the screening, many owners switch to "solar screening".
Helps to keep the trailer cooler in the summer.
10-09-2010, 01:42 PM
1973 25' Tradewind
Albuquerque
, New Mexico
This is maybe a dorky question, but do I need to remove the whole inner frame from the windows on my 73 Tradewinds in order to replace the cat-damaged screens, or can I simply pull out the spline and put in new screen and spline? I may be looking to sell it soon and would like to get them replaced. Thanks!
10-09-2010, 01:54 PM
1973 23' Safari
Encino
crlaurence.com / 800 421 6144
Summer screen sale is over but look for it in their catalog library. They will have what you need all year round.
10-09-2010, 05:52 PM
1993 34' Excella
Estancia
, New Mexico
It can be done but it is easier and probably quicker to take out the frame.
10-09-2010, 06:41 PM
Rivet Monster
1975 31' Sovereign
1980 31' Excella II
Sprung Leak
, North Carolina
FWIW I would put the screen and spline in with the screen mounted to the wall. If you do them on a flat surface the screen will wrinkle and pull when you reinstall it on the curved side of the AS. Been there done that and redid them.
Aaron
WBCCI #XXXX AIR #2495
10-09-2010, 06:50 PM
1993 34' Excella
Estancia
, New Mexico
They also make critter claw resistant screen. I also find fiberglass screen a lot easier to work with than aluminum.
10-09-2010, 09:53 PM
1973 25' Tradewind
Albuquerque
, New Mexico
Aaron
Sorry, do you mean install without removing the inside frame? If so, what do you do with the cut edges of screen material after putting the spline on? I love this forum!
10-10-2010, 06:19 PM
1993 34' Excella
Estancia
, New Mexico
I spose u cud screw the frame to a piece of plywood and have your cake and eat it too. Never have done it. Obviously, some screens will be more difficult to replace in position.
I use a sharp utility knife and a cuticle scissor to do the trim.
10-10-2010, 06:24 PM
Rivet Monster
1975 31' Sovereign
1980 31' Excella II
Sprung Leak
, North Carolina
Yup install with the inside frame mounted. I cut the leftover screen with a very sharp razor knife or single edged razor blade.
Aaron
10-10-2010, 06:25 PM
1973 25' Tradewind
Albuquerque
, New Mexico
Thank you, Lumatic - I am of the "less is more" philosophy in most aspects of life, so I'm going to take a page from your book and simply leave the frames where they are. So excited, it will totally improve the look of my Airstream! thanks again - PK
10-10-2010, 06:28 PM
1993 34' Excella
Estancia
, New Mexico
Removing the screen frames also makes it easy to give the frame a nice fresh coat of spray paint.
