Old 11-09-2013, 09:06 PM   #15
Originally Posted by capt ken View Post
Does that also apply for a 70 international Andy? If so I will have to remove the gasket from the top before I close it.
The window gasket for 1969 and up trailers, goes on all 4 sides as one piece.
The seam must be at the bottom and near the center of each opening window.
Old 01-28-2018, 03:19 PM   #16
S/O#080
Tschupp's Avatar
2006 30' Classic S/O
Tucson , Arizona
Iím using Motsenbockerís Lift Off. It is a tape, label and adhesive remover. I removed old gasket, applied remover to rag, wiped down remaining gasket let sit for a few minutes. Used razor blade to complete removal. Lightly sanded area, rubbed down with steel wool. Clean with soapy water dry throughly. Apply new gasket. Is working so far. The test will be how is it holding up in 6 months. In a week or so spray with a silicon spray. Wipe clean in a couple of days.
Tschupp is offline   Reply With Quote
