Old 01-12-2014, 08:09 PM   #1
desertair27's Avatar
1960 26' Overlander
1963 24' Tradewind
El Paso , Texas
Images: 32
Replacing window and hinge on a '68
I have a complete side window I'd like to replace on a 68 Sovereign. It has the hinge attached to the window already but how does the old window hinge come out?
Mike
desertair27 is offline   Reply With Quote
Old 01-12-2014, 08:12 PM   #2
Aviator's Avatar
1997 34' Limited
1970 27' Overlander
South of Atlanta , Georgia
Do you have a picture? The windows on my 1970 have a two piece hinge across the top. Part is fixed to the trailer, and the other is a "J" shaped part which is riveted to the top edge of the frame around the glass. The "J" hooks into the part affixed to the trailer. The only way to remove it would be to drill out the rivets (1/8).
Craig and Carol
1997 34' Excella 1000
1970 27' Overlander, International
2009 Ford F150 5.4L
ProPride hitch with 1400# bars
AIR 41028
TAC GA-8
WBCCI 10199
Past President Southeastern Camping Unit (12)
Aviator is offline   Reply With Quote
Old 01-12-2014, 08:26 PM   #3
1960 26' Overlander
1963 24' Tradewind
El Paso , Texas
Images: 32
This window is one of the unique Corning windows only installed on the 66-68 models. I'm thinking it has to come in the same way you describe though. Just hoping to verify. Thanks Craig Mike
Old 01-12-2014, 08:56 PM   #4
DFlores's Avatar
1968 22' Safari
First detach the arm that raises the window, there is a snap ring on the inside. Then remove the small metal tab that limits the window movement forward and back, this is removed by pulling straight down with a set of needle nose pliers, be careful with the tab. Next lift what you have in place for a window or just the hinge a work past where you removed the tab. Sometimes there is not enough clearance to remove window, most will not agree, but I pry hinge attached to trailer open a little to create clearance. Slide window out.
DFlores
David & Diana
DFlores is offline   Reply With Quote
Old 01-12-2014, 09:03 PM   #5
1960 26' Overlander
1963 24' Tradewind
El Paso , Texas
Images: 32
So if I understand this right the window hinge is suppose to slide out to the side? The trailer is at storage so I can't run out and look at it right now but I'll think about what you're saying.
Mike
Old 01-13-2014, 06:51 AM   #6
Aviator's Avatar
1997 34' Limited
1970 27' Overlander
Thanks for the picture. That is the first time I have seen one of those.
Craig and Carol
2009 Ford F150 5.4L
AIR 41028
TAC GA-8
WBCCI 10199
Old 01-13-2014, 12:29 PM   #7
DFlores's Avatar
1968 22' Safari
Mike
Yes, you got it.
DFlores
David & Diana
Re-installation Rear Window Glass 1968 Overlander International Rhodo1937 Windows & Screens 17 07-17-2016 07:32 AM
Window Extrusion ? DontBSilly Windows & Screens 16 03-21-2012 07:04 PM
How to replace a window?? UAPachyderm 2002 - 2005 International 11 10-14-2011 03:47 PM
2007 Classic front center window glass/frame interference dznf0g 2006 - 2010 Classic (all lengths) 0 03-23-2011 09:44 AM
Front and Rear Window hinge - 1968 Randy Gates 1965 - 1969 Globetrotter 1 01-15-2011 10:05 PM
