Old 11-17-2009, 05:25 PM   #1
Globie64's Avatar
1964 19' Globetrotter
The Sea Ranch , California
Images: 18
replacing tubular bead on '64 windows
Anybody replaced the bead between the frame in the trailer and the window sash, shaped like a tube with a kind of molded in place flange, that theoretically slips into a slot in the window frame in the trailer? Seems simple, but would love to hear anyone else's experiences or comments.
thanks
Peter
Wherever you go, there you are
Globie64 is offline   Reply With Quote
Old 11-17-2009, 05:34 PM   #2
thanks
Peter
Using the hollow window gasket, is not really making any improvements.
If you use the "D" shaped gasket, that's hollow, then you would have made a huge improvement.
The "D" shaped gasket is attached not to the glass frame, but the the meatl frame that's riveted to the shell.
Repeated tests shows an excellent seal with the "D" gasket.
Many owners have switched to it for it's obvious improvement over the old hollow bulb gasket.
Old 11-17-2009, 05:58 PM   #3
silverleeper's Avatar
1967 22' Safari
1960 Caravel
Edmonds , Washington
Images: 8
thanks
Peter
Hi Peter, It is simple. Take a look here. Restoration Topics - Window Repairs. We have had no problems with leaks.
Lee
1973 F-250 4X4 390
1965 Chevy Suburban 454
AIR 6030
WBCCI 4258
TCT
silverleeper is offline   Reply With Quote
Old 11-17-2009, 06:45 PM   #4
Lee.
That gray gasket was last used by Airstream in 1965.
Forty some years of gasket technolgy has brought that subject, thousands of miles.
The basic problem with the gray material is that is has no body. When it's exposed to warmer climates, it fails fast.
Secondly, it does a poor job of sealing, if the window operators have a little play, as well as being in the rain, while towing.
Heavier bodied gaskets are far superior, hands down.
Ask those that have upgraded to the newer style of "D" gasket.
Changing window gaskets, should nor be a must every couple of years. With the gray material, that's exactly what you must do.
With the "D" gasket, you might need to change them after 20 to 25 years.
Huge difference.
Old 11-18-2009, 10:04 AM   #5
1967 22' Safari
1960 Caravel
Images: 8
Originally Posted by Inland RV Center, In View Post
Lee.
Huge difference.
Thanks for your concern Andy, I installed Hehr Window Bulb Seal over 5 years ago and have not had any window leaks and the Hehr Window Bulb Seal is showing no sign that it needs replacing. The Hehr Window Bulb Seal I purchased and installed is not old stock from 50 years ago. I live in the Pacific NW were the weather can be a challenge with hot summers and cold rainy winters.
Bottom line for me is it's original to the trailer and thats what I want. All I did was give Globie64 a reference to repair his window. I do not profit from any post I make.
Lee
1973 F-250 4X4 390
AIR 6030
WBCCI 4258
TCT
Old 11-18-2009, 12:11 PM   #6
Globie64's Avatar
Images: 18
Thanks Silver Leeper, thats the way I feel as well.
"...Bottom line for me is it's original to the trailer and thats what I want. All I did was give Globie64 a reference to repair his window. I do not profit from any post I make."
and thanks for the connection to the other thread. I've bought different seals from other vendors over the last 8 years, with terrible results. I'm attempting to use the stuff that is as close to original as I can. Central coastal california has about a benign a climate as you can find, so we're lucky there.
Peter
Old 11-18-2009, 12:13 PM   #7
Globie64's Avatar
Images: 18
wow, I just looked at the pics on the vintageairstream site, it looks great, thanks!
Old 11-18-2009, 12:23 PM   #8
1962 28' Ambassador
1962 30' Sovereign
Webster Groves , Missouri
Lee.
Huge difference.
Pictures? Link to pictures? Installation guide?
Xbob2 is offline   Reply With Quote
Old 11-18-2009, 12:27 PM   #9
Globie64's Avatar
Images: 18
Bob, this is the page
Peter
Old 11-18-2009, 12:40 PM   #10
1962 28' Ambassador
1962 30' Sovereign
Peter
Thanks, but I was asking Inland Andy about his superior product ...
Old 11-18-2009, 01:46 PM   #11
Bob.
That "D" gasket is in our web site, part # 45370.
It can be installed on the window frame that's riveted to the shell, or on the backside of the metal frame around the glass.
It's held in place with 3M super weatherstrip adhesive.
After installation, coat it once a year with a bit of silicone spray, and that keeps the gasket alive for at least 20 tears or more.
Old 11-23-2009, 11:19 AM   #12
Globie64's Avatar
Images: 18
Xbob2, I'll be curious to know how that works for you. I hope to get to my project this Friday.
Peter
Old 12-03-2009, 08:49 AM   #13
bwaysteve's Avatar
1965 28' Ambassador
Irving , Texas
D weather strip
I am getting my 1st AS this week ,a 65 Amb. I thought the first order of biz would be to seal all windows with new stripping.
Is something else used for the non movable windows front and rear?
bwaysteve is offline   Reply With Quote
Old 12-03-2009, 09:01 AM   #14
1967 22' Safari
1960 Caravel
Images: 8
Keeping the inside dry is a good first step. I assume the front non movable windows are by the door lower curd and street side. I'm not sure where the non movable window is in the rear.
Sealing the seams is a good step too. http://www.airforums.com/forums/f456...more-7626.html
Lee
1973 F-250 4X4 390
AIR 6030
WBCCI 4258
TCT
Old 12-07-2009, 02:53 PM   #15
Globie64's Avatar
Images: 18
First try at the bulb weatherstripping replacement went pretty well- the old stuff is hard and flattened, and either glued in place or wedded to the aluminum after 45 years. The new bulb weather stripping went in really easily and looks great. We had rain last night and I'm going to go see if there was any leaking.... I've had numerous weatherstripping issues, now it looks like more appropriate rubber profiles are available from Vintage Trailer supply, I' m ready to tackle the front door and screen, for the third time.
replacing Corning windows '68 Trade Wind IndyAnne Windows & Screens 3 06-16-2009 09:14 AM
Replacing Windows on our '67 Redbutton Windows & Screens 9 03-01-2009 11:36 AM
Thank goodness for Airstream's tubular shape! Becky B. Off Topic Forum 14 02-22-2008 08:28 PM
Replacing the curved windows in the Argy Chopper Windows & Screens 5 09-21-2006 03:40 PM
Replacing Windows larrylisa Windows & Screens 9 01-30-2003 04:50 PM
