Old 10-22-2012, 08:16 AM   #1
jornvango's Avatar
Replacing the door screen? (newbie alert)
We bought our '95 Sovereign (21ft) last week.
The lower bug screen in the door is broken (pet damage).
Is it an easy thing to replace ourselves, or should we take the AS to a screen repair store?
Thanks!
jornvango is offline   Reply With Quote
Old 10-22-2012, 08:18 AM   #2
c_lewis77's Avatar
1982 34' Limited
Brunswick , Georgia
Images: 22
I just replaced mine, it took about 5 minutes to do the whole thing. I would go ahead and do the whole door so the screen matches.
1982 34' Limited
2000 Excursion V10 4x4
WBCCI #3321
TAC #GA-24
c_lewis77 is offline   Reply With Quote
Old 10-22-2012, 08:56 AM   #3
1976 31' Sovereign
Oswego , Illinois
Smile sceen replacement
Pur. new fiberglass screening, cheap screen spline roller, use nut pick or pointed tool pick out spline cut screen a little over size start spline in groove then roll in around opening thats it very simple
Old 11-01-2012, 02:19 PM   #4
jornvango's Avatar
Thanks! I purchased the supplies at Home Depot today so tonight I'll give it a try.
I guess it would be easier to do if I could take off the screen door, but it's attached with rivets, which I have no idea how to remove/re-attach later! (newbie here)
So, I'll try it with the door attached.
Old 11-01-2012, 04:30 PM   #5
Full Timers/Diesel power.
Mike Leary's Avatar
Cactus Hug , Arizona
Images: 11
Let us know how it worked: our dog just poked a hole in ours, and I'm not interested in pulling the door.
"A settled wisdom, plus the itch to be elsewhere"
Mike Leary is offline   Reply With Quote
Old 11-01-2012, 04:33 PM   #6
Silverflames's Avatar
1969 29' Ambassador
brooksville , Florida
I used the pet grade screen when I did mine. It looks darker and is almost like a sun screen. Down side was that it's so thick its hard to install. I did not pull my door when I did it. If I remember correctly I used clamps to hold the top in place while I worked on it.
Silverflames is offline   Reply With Quote
Old 11-05-2012, 10:20 AM   #7
jornvango's Avatar
It worked and it looks great!
Not that difficult... although on the first attempt I did manage to slip while using the spline roller and it poked a hole in the almost installed screen ... The 2nd try worked out better
Old 11-05-2012, 10:24 AM   #8
Mike Leary's Avatar
Images: 11
Can anyone post pics of the tools needed to do the screen?
Old 11-05-2012, 11:08 AM   #9
fltlevel510's Avatar
2004 30' Classic Slideout
Between Here , And There
Replaced the screen in our Airstream some years ago with lexan. Now we leave the main door open most all the time even with heat or AC on. Allows plenty of light in the Airstream and gives a great feeling of openness.
fltlevel510 is offline   Reply With Quote
Old 11-05-2012, 11:34 AM   #10
jornvango's Avatar
Mike,
Here is the spline roller: Shop Phifer Spline Roller with Plastic Handle at Lowes.com
Here is an example of the spline Shop New York Wire .125 x 100 Ft. Gray Spline at Lowes.com=
You'll need to buy the actual new screen itself.
And the last thing is a knife to cleanly cut the extra screen sticking out.
The only thing I'm not certain about is the needed thickness of the new spline. I read somewhere it's 0.125'. However, I'm not certain since I was able to reuse the one in my old screen door.
Old 11-05-2012, 12:00 PM   #11
StreamRollin's Avatar
1999 25' Safari
Denver , Colorado
Help me out here, what is Lexan?
Thanks Jim
Jim D.
AIR # 56543 TAC# CO-10
StreamRollin is offline   Reply With Quote
Old 11-05-2012, 01:50 PM   #12
c_lewis77's Avatar
1982 34' Limited
Brunswick , Georgia
Images: 22
Jim:
Lexan is a brand of plexiglass
1982 34' Limited
WBCCI #3321
TAC #GA-24
Old 11-05-2012, 01:50 PM   #13
1969 29' Ambassador
It's a clear sheet of hard plastic. Plexiglass, lexan is a trade name, and I think it's a little stronger than plexiglas?
Old 11-05-2012, 02:53 PM   #14
jimmickle's Avatar
2000 31' Land Yacht
they are different materials. plexiglass is acrylic and lexan is polycarbonate, much stronger and tougher. downside, it fails when in contact with hydrocarbons.
jimmickle is offline   Reply With Quote
