Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Windows, Doors, Locks & Vents > Windows & Screens
Old 09-21-2006, 12:30 AM   #1
Chopper
Profile:  1976 26' Argosy 26
St. Albert , Alberta
Replacing the curved windows in the Argy
Hi all,
Is the following the correct understanding of replacing the curved front window in my Argy?
1. remove all those rivets off the frame,
2. take off the frame,
3. take out the window (plexiglass in my case),
4. put in the new window,
5. reseal and put the frame back on with all those rivets.
If that's the case, then the inside doesn't get touched right? Then how is the inside "ledge" of the window cleanly finished? My Argy looks as follows:
Thanks!
Name:	Day Seven Left Wing Interior (reduced).jpg
ID:	26154  Click image for larger version
Name:	Day Seven Right Wing Interior (reduced).jpg
Chopper is offline   Reply With Quote
Old 09-21-2006, 03:19 AM   #2
wahoonc
Rivet Monster
wahoonc's Avatar
Profile:  1975 31' Sovereign
1980 31' Excella II
Sprung Leak , North Carolina
Images: 35
Chopper,
I am not an Argy owner so you may have to wait for a definitive answer...but on the Airstream there is a plastic surround that covers up the cut edges on the inside. On the side (flat) windows the screens cover up those edges.
Aaron
WBCCI #2449 AIR #2495
Old 09-21-2006, 05:08 AM   #3
balrgn
balrgn's Avatar
Profile:  1974 27' Overlander
Rockingham County , New Hampshire
Images: 74
The window comes out all one piece, frame and all.
'74 Overlander (T-O-Bee)
'46 Spartan Manor (Rosie)
'77 20' Argosy MH (Peanut)
2006 GMC Sierra 5.3 V8
WBCCI 1754 - AIR # 6281
Member of VAC
www.balrgn.com
www.balrgn.com/Airstream.htm
balrgn is offline   Reply With Quote
Old 09-21-2006, 11:18 AM   #4
Chopper
Hi,
Balrgn,
Since I contacted you about the Argy you're parting out (I asked about buying the shell) I found my Argy in a lot less than half an hour away. But FYI I got a couple of freight rail quotes and the cheapest was $3600 not including handling and taxes. Ouch. But that's clear across the continent and up into Canada!
But about the window...when I take all those rivets out, the whole window comes out? Hmmm...I was hoping that on the curbside (the photo on the right) that I would pop the Herculite out and clean up the gunk you see building up on the inside of the window where the old caulking is). Ugh! But that won't be the case if the whole assembly comes out.
Cheers!
Old 09-21-2006, 11:37 AM   #5
balrgn
balrgn's Avatar
Images: 74
I still have the curb side window for sale, I'll post a pic later on
Shipping is brutal to Canada......
Member of VAC
www.balrgn.com
Old 09-21-2006, 03:40 PM   #6
balrgn
balrgn's Avatar
Images: 74
I mis-remembered. The frame does not come out just the window.
ID:	26161  Click image for larger version
Member of VAC
www.balrgn.com
Wondering what kind of glass to use for replacing all windows in 1958 Traveller williamhenshall Windows & Screens 3 08-19-2007 08:15 PM
Water leak panoramic windows Andy Fay Windows & Screens 16 01-05-2007 09:33 AM
Acrylite (Smoked, Curved & Installation) Cat Windows & Screens 4 05-23-2005 03:04 AM
Windows Inland RV Center, In Windows & Screens 1 04-20-2004 07:14 AM
Caravel windows susan martin 1966-68 Caravel 1 08-21-2002 09:43 AM
