Old 05-02-2012, 07:32 AM   #15
Originally Posted by DixieDarlin View Post
Update - yesterday I installed the bulb gasket from Vintage Trailer Supply on three windows. I went all the way around each window with the gasket. It took three hours mainly because I had to pull out old silicone from the POs repairs. Thank goodness he hadn't applied much of it. This weekend I'll install on the other three windows. I'm keeping my fingers crossed that it will pass the water hose test!
The bulb gasket was discontinued early in it's life because it's an absolute failure for even the short haul.
The "D" gasket is far superior and has none of the faults of the bulb gasket.
Watch what happens when you squirt water to the side of the window frame, which is the same as towing in a rain.
The water will go right past the bulb gasket.
Old 05-02-2012, 01:06 PM   #16
DixieDarlin's Avatar
1964 19' Globetrotter
Boyce , Louisiana
Ok I'll check it out. Thanks!
DixieDarlin is offline   Reply With Quote
Old 08-07-2012, 08:04 PM   #17
SpikeC's Avatar
1958 26' Overlander
Portland , Oregon
We just picked up our '58 Overlander, formerly Mello Mike's Lucy, and pulled it from St. David, AZ to Portland, OR through some amazing downpours in AZ and CA. We had some intrusion around the edge of the outer door, but the windows did not seem to leak at all.Some of the seals around the windows do not look very good at all, although Mike did some well documented work on leakery! We have found all sorts of odds and ends in the trailer including a bunch of gasketry. Now all we have to do is figure out what to do with the stuff we found in the trailer!
SpikeC is offline   Reply With Quote
Old 12-17-2014, 06:11 AM   #18
robwok's Avatar
1964 26' Overlander
Richmond , Virginia
Images: 35
Andy: Can you provide a link to the gasket you're referring to? I've never had much luck using the search engine on your site. Also, the bulb gasket has a lipped piece that goes in the original slot. I think I found the D gasket you're referring to, but would like to know the size. I'm assuming you just stick it on?
Rob.
robwok is offline   Reply With Quote
Replacing windows seals Shawnna Leaks - Weatherstrips, Gaskets, Caulks & Sealants 11 07-21-2014 11:55 AM
310 windows seals and weep hole covers montreal Classic Motorhomes 22 01-02-2013 05:32 AM
Replacing Window seals throughout 68 Safari Dazzler Windows & Screens 0 07-27-2010 10:14 PM
Windows, windows, windows... Balquin Windows & Screens 4 07-04-2006 06:35 PM
New seals for windows linjoe21 Windows & Screens 1 04-17-2004 03:57 PM
