Old 06-14-2009, 09:21 AM   #1
A 7th year newby
IndyAnne's Avatar
1968 24' Tradewind
Indianapolis , Indiana
Images: 8
Send a message via Yahoo to IndyAnne
replacing Corning windows '68 Trade Wind
Hi, I am looking for some step by step photos on replacing broken windows with Corning curved glass, and front window. Naturally, I have lots of questions :-)
I have the glass and new stainless steel trim and the clips for the sill catches. I am still searching for a replacement for the rear sill http://www.airforums.com/forums/show...92&postcount=1
I want to be sure I take the windows all apart and reinstall correctly. I have air tools, Olympic and solid rivets, butyl tape, bulb-type seals.
As for trimming the class with the stainless steel, can I use any type of glazing for seating the glass into the SS channel, or is there something specifically for this purpose?
I've been combing through the forums all morning, not finding exactly what I am looking for, so I'll take my camera with me and start shooting my own steps. Meanwhile, if anyone has tips and tricks to recommend, I'm all ears.
Anne
Anne
Indianapolis, IN
TAC IN-7
1968 Airstream Trade Wind
2005 Chevy K1500 crew, reg. bed, 4WD, gas
IndyAnne is offline   Reply With Quote
Old 06-15-2009, 06:29 PM   #2
Stefrobrts's Avatar
1968 17' Caravel
Battle Ground , Washington
Images: 50
Hi Anne,
I replaced my kitchen corning window last year when I accidently put a rock through it with the string trimmer while cutting weeds nearby. It was not difficult at all. No rivets are involved. You simply take the hinge apart at the top and put the new glass in with a piece of double stick thick tape-like material, which I got from the local glass shop when I explained to them what I was doing.
I never did find a replacement trim for the edges though. I used the Vintage Trailer Supply glass and it was too thick for the original trim. Where did you get your edge trim from?
Stephanie
Old 06-16-2009, 08:01 AM   #3
byamcaravanner's Avatar
1967 28' Ambassador
1963 19' Globetrotter
1970 29' Ambassador
Waukesha , Wisconsin
Anne,
Here is some great info on just what you are looking for.
Steve & the crew
'70 Ambassador International Twin
'63 19' Globetrotter TAC WI-1
http://byamcaravanner.blogspot.com/
byamcaravanner is offline   Reply With Quote
Old 06-16-2009, 08:14 AM   #4
A 7th year newby
IndyAnne's Avatar
1968 24' Tradewind
Images: 8
Stephanie, thanks for your reply, which gives me more confidence to get this done. My kitchen window has a thick piece of plastic now. I have the glass from VTS, also. They also have the trim.
Anne
Anne
Indianapolis, IN
TAC IN-7
corning glass, phillips, window, 1968 tradewind, replace
