Old 08-08-2004, 05:43 PM   #1
Marc's Avatar
Question Replace window screens
In addition to my Caravel I have a 1954 22' Silver Streak Clipper. I want to replace my window screens but I am unsure of the technique and/or tools to do this. Can anyone offer information as to procedure and/or special tool needed. Any help will be appreciated. I do not have spline inserts - this trailer uses another method. Thanks, Marc.
Marc is offline   Reply With Quote
Old 08-08-2004, 06:43 PM   #2
BobbyW's Avatar
1965 20' Globetrotter
Houston , Texas
What kind of frames does it have. Spline inserts?
If so just go to the big-box home center and they will have everything you need. Sceening, tool and rubber spline.
BobbyW
AIR# 123
-"You want to make it two inches - or, if you're working in centimeters, make sure it's enough centimeters for two inches."-Red Green
BobbyW is offline   Reply With Quote
Old 08-08-2004, 07:08 PM   #3
Marc's Avatar
No spline inserts
I don't have spline inserts. I have done those before on a motor home. These are different. I've never seen this sort of setup before. If you know of anyone who has a Silver Streak Clipper, perhaps they might know. We really appreciate your input - thank you for answering. Marc
Old 08-08-2004, 07:48 PM   #4
BobbyW's Avatar
Houston , Texas
My Father-in-law has a Silver Streak, but I am not sure if it is a Clipper. I'll have the wife ask him tomorrow during her daily phone call.
BobbyW
AIR# 123
Old 08-08-2004, 07:52 PM   #5
Marc's Avatar
Wink Yes Please
Yes, that would be great. I suppose it should be a old Silver Streak because it's old technology I'm dealing with. I will take some digital photos of the area and post them sometime this week on this site. Thanks again, Marc.
Old 08-08-2004, 10:17 PM   #6
JohnG's Avatar
Originally Posted by Marc
Yes, that would be great. I suppose it should be a old Silver Streak because it's old technology I'm dealing with. Thanks again, Marc.
If you can post a photo someone might be able to help you that has dealt with that in the past too.....................
Just adding my 2¢ worth
John G
___________________________
1975 31ft Sovereign International
........Rear Bath Double Bed Model
Tow Vehicle:1999 GMC Serria SLE Classic 1500 5.7Ltr
System: Jordon 2020 Ultima Brake Controller
Hook-Up: Equalizing Hitch and Sway Bar
JohnG is offline   Reply With Quote
Old 08-12-2004, 03:35 PM   #7
Marc's Avatar
Question Pictures of '54 Silver Streak Clipper Window Screens
I have attempted to do as John suggested and take digital pictures of the window screens that I need to replace in my 1954 22' Silver Streak Clipper.
Picture #1 is of the overall type of window.
Picture #2 is a closeup of the upper right hand corner of the window.
Picture #3 is a closeup of the curved metal frame that the mesh wraps around. As you can see, the mesh is torn at the edge.
Picture #4 is more of the same and so is Picture #5.
If you use Microsoft Picture It or Kodak Picture Software I believe you can Zoom in to get a really good look as the shape of this frame.
It is not the type (I don't believe) that uses a normal screen tool with beading.
Has anyone used a tool for this type of trailer or perhaps one of a similar vintage? If so, can one still be purchased or would it need to be fabricated? Any help would be greatly appreciated.
Thanks, Marc
Wanting to replace the WHOLE bathroom... larrylisa Sinks, Showers & Toilets 24 04-01-2015 10:19 AM
Replace original vent pipe cover? rluhr Roof Vents, Skylights & Fans 18 08-30-2004 12:12 PM
repair or replace a/c? hively Furnaces, Heaters, Fireplaces & Air Conditioning 12 07-19-2004 11:37 PM
window screens - fuzzy things Craig Windows & Screens 2 09-03-2003 07:18 AM
need to replace the wheel...are there jacking points? 60traveler Jacks, Stabilizers, Lifting and Leveling 1 06-25-2003 03:05 PM
