Old 05-01-2010, 01:00 PM   #1
2005 19' Safari
GLENDALE , AZ
Replace 'Smoked' Window in Door with Clear One
Has anyone ever replace the "smoked" window in the door with a clear one that you can see out of?
It puzzles me that the factory would install a window here that you can't see through. Wouldn't you want to be able to see if it was safe to open the door?
(2005 Bambi, 19-foot)
Old 05-01-2010, 01:41 PM   #2
CanoeStream's Avatar
St. Cloud , Minnesota
Is it a curved window? (it is on my '06 Safari) All the other windows on my Safari have blinds to provide privacy. The door window is frosted on mine. Blinds sure wouldn't work on a door. So my feeling has been that they want to give you the opportunity for privacy. Open any blinds you want if you want to share with the world.
In most camping weather anyway, my outer door is open and just the screen door is closed.
It might be a trick to provide a curved, clear, tempered window. And then have a competent shop remove the frame, install the window, seal and re-rivet the frame. Sikaflex, Olympic rivets, and a rivet polisher certainly could make this an invisible changeout. Please to provide pictures if you do this!
5 meter Langford Nahanni
Old 05-01-2010, 05:41 PM   #3
Phantom's Avatar
2007 19' Bambi
Delton , Michigan
Replaced Mine :)
Hi Phoenix... I had mine replaced on our 2007 Bambi Safari 19'. I too couldn't understand a door window I couldn't see out of! Took it to an automotive glass shop and had it switched to dark gray tinted plexiglass. (Looks same dark tint as all the other windows. I like it! Haven't come up with an appropriate 'curtain rod' arrangement on the inside yet, so we hang a towel over the window at night. It's not curved enough to make a big difference. The plexiglass is flat. No problem.
Phantom is offline   Reply With Quote
Old 05-01-2010, 07:21 PM   #4
More than one rivet loose
thecatsandi's Avatar
Keymar , Maryland
Privacy,
It is the only window without a blind.
Michelle TAC MT-0
Sarah, Snowball
Old 05-01-2010, 07:53 PM   #5
Dare I play with this?
www.boinkin' boris.com
Video at 10:00....
Though it looks like Phantom has arrived at a solution.
how to replace a side window on a 2008? Randjg1 Windows & Screens 0 09-15-2009 11:46 AM
Clear Wrap Window Glass and other related questions StAlphonzo Windows & Screens 4 06-11-2008 08:49 PM
window leak/repair/replace? gwendolyn Windows & Screens 1 01-22-2006 10:09 AM
Removing Smoked Plexiglass Window Shields Lee Davis Windows & Screens 4 09-13-2005 02:41 PM
Replace window screens Marc Windows & Screens 6 08-12-2004 03:35 PM
