Old 10-07-2010, 03:51 PM   #1
lucymcdog's Avatar
1965 24' Tradewind
Saguache , Colorado
Replace/repair screens
Does anybody know how to repair or replace the screens on my 1960 18' Traveler? The handle that opens the window goes through the screen and is riveted to a little frame piece which is on top of the screen. I hope I don't have to take out the rivets because I don't even own a rivet gun. But can get one if I have to...
lucymcdog is offline   Reply With Quote
Old 10-07-2010, 04:12 PM   #2
wkerfoot's Avatar
1979 23' Safari
1954 29' Liner
Orange , California
That is the same window latch I have in my 1954 Liner, I thought they were only used in the early 1950's and were replaced by crank openers. Regardless, you need to drill out the rivets holding the latch to the frame. I used pop rivets to replace the latch. A pop rivet gun is only a few dollars and you should have one in your tools, also aluminum, not steel rivets.
Bill
Just my personal opinion
wkerfoot is online now   Reply With Quote
Old 10-07-2010, 04:21 PM   #3
lucymcdog's Avatar
1965 24' Tradewind
Saguache , Colorado
Thanks Bill. Can you tell me what size rivets to get? And do I need a hand-held rivet gun or one that attaches to my compressor? Or is a pop rivet gun different from a "real" rivet gun?
Old 10-07-2010, 04:27 PM   #4
silverleeper's Avatar
1967 22' Safari
1960 Caravel
Edmonds , Washington
Images: 8
This might help you. 1956 Flying Cloud - Windows.
Lee
1973 F-250 4X4 390
1965 Chevy Suburban 454
AIR 6030
WBCCI 4258
TCT
silverleeper is offline   Reply With Quote
Old 10-07-2010, 04:33 PM   #5
wkerfoot's Avatar
1979 23' Safari
1954 29' Liner
Orange , California
A pop rivet gun is different, a hand gun will work great. If you want to install a hundred or so rivets get one which attaches to the air compressor. I use 1/8" diameter with a grip range of 1/8".
Bill
Old 10-07-2010, 05:11 PM   #6
lucymcdog's Avatar
1965 24' Tradewind
Saguache , Colorado
Thanks Lee. Great photos and it is exactly the kind of screen setup I have. Question though - I looked for a "Walter Finishing Line Tool" (your link didn't work) and am not really sure what I need to get. I only have 4 windows in the whole trailer so maybe I can get by with naval jelly and steel wool? Did you then paint the pieces with shiny metal paint? Yours look really good!
Old 10-07-2010, 05:42 PM   #7
1967 22' Safari
1960 Caravel
Images: 8
Thanks, But it is not my site. This fine site was put together by R.J. Dial Vintage Airstream Home. Give it a look when you get a chance.
From the photos I came up with this link. Products. Hope this helps.
I'd probably try your method first.
Lee
1973 F-250 4X4 390
AIR 6030
WBCCI 4258
TCT
Need Help cleaning our screens and vent screens ctalley316 Full-Timing 3 09-19-2008 11:48 AM
Coleman AC repair or replace LI Pets Furnaces, Heaters, Fireplaces & Air Conditioning 4 09-26-2006 12:47 PM
Replace window screens Marc Windows & Screens 6 08-12-2004 03:35 PM
repair or replace a/c? hively Furnaces, Heaters, Fireplaces & Air Conditioning 12 07-19-2004 11:37 PM
Sink...Repair or Replace?? COArgosy78 Sinks, Showers & Toilets 17 08-05-2003 03:28 PM
