Old 12-21-2011, 04:51 PM   #1
ASNomads's Avatar
1978 28' Ambassador
Byfield , Massachusetts
Replace Caulking on Outside of Windows
Hi all,
What material do I want to use to replace the outside caulking on the 70s window?
Is the application simply done with a caulk gun? Anything to be aware of?
Georgie
ASNomads is offline   Reply With Quote
Old 12-21-2011, 06:20 PM   #2
Top
Always learning
Top's Avatar
1972 29' Ambassador
1962 19' Globetrotter
1951 21' Flying Cloud
Central , Texas
Images: 24
Send a message via Yahoo to Top
Hi Georgie,
Welcome to the forums. What you are describing as caulking is the gasket that the window panes are set into the outer frame. You can reseal them with any good polyurethane sealant. You can use Trempro 635, Sonolastic NP 1, 3M 540 or Sikaflex 221. I recommend masking off the outer frame then apply sealant with a caulking gun, tool, then wipe off excess with a cloth moistened with mineral spirits.
This thread has a lot of info on completely rebuilding windows.
Lance
Top is offline   Reply With Quote
Old 12-21-2011, 07:03 PM   #3
ASNomads's Avatar
1978 28' Ambassador
So if I would wana do it right, I would actually take apart the whole window and replace the gasket!?
I have single pane windows which seems to make the job easier than in the thread you shared.
Any idea where can I find the right gasket? Couldn't locate it at ODMRV at a quick glance...
Georgie
Old 12-21-2011, 07:10 PM   #4
Top
Always learning
Top's Avatar
1972 29' Ambassador
Central , Texas
Images: 24
It is probably not necessary for a single pane window. Most people only take apart the double pane windows because they can't see through them because of the window film applied to the inside of the outer pane. If you just do the simple method above, I'm sure you will have many years of leak free windows.
Lance
caulk, sealant
NEEDED: Two front windows for '71 Overlander jesse_kevon Windows, Doors, Locks & Vents 4 05-30-2015 09:26 AM
What type of caulking material to use? chrischarles Leaks - Weatherstrips, Gaskets, Caulks & Sealants 29 11-08-2011 10:43 AM
Replace old windows with modern?? hotstuff Windows & Screens 3 03-23-2011 11:30 AM
'73 Tradewind Windows Vista and Front Sides constructor Windows & Screens 8 01-28-2011 05:44 AM
To replace or not to replace the axles airstrmkids Axles 17 01-13-2011 06:20 AM
