11-11-2009, 05:59 PM
#81
1976 29' Ambassador
Wichita
, Kansas
Am new to the forum and to Airstreams for that matter. The windows on one side of my just purchased 1976 29ft. Airstream are full of bubbles and very foggy. Am considering ordering new window sashes from Airstream to replace the existing ones ( need three).
Mike
11-15-2009, 02:06 PM
#82
1977 31' Excella 500
Guntersville
, Alabama
I've got two of the later versions and one of the earlier out in the shop, I just not
Originally Posted by Zeppelinium
Not a chance!
The Vista View windows come in two types--early 70's had a flat retaining "ring/clip" that you could pull out, which released the inside pane (which was plexiglass). Taking that clip out could be done with the window installed in the shell. The frame is welded and the clip is the only access. I did one back in 1998 using plumber's putty (which is all I knew about back in those days) and it didn't hold up very long--blobs of putty sliding down in the window in the heat of the Mojave sun. But I did manage to get the solar film cleaned up.
The later Vista Views (maybe 1975 and on) have two frame halves riveted together, just like the larger windows. But this means that to get them apart you have to remove the whole frame/window from the shell. PITA for sure.
If you're not familiar, my solution (in another thread) was to completely remove all vista view windows and patch them over with 2024-T3.
The bottom line is, however, I'm not fooling around with Vista Views. I don't need badly insulated and leaky ports in my shell--which is a mild version of what I really think.
Zep
I would really like to get a hold of an upper vista view with good outer glass. If you're willing to sell one let me know. I had a shattering experience trying to break out the inner glass without knowing it is NOT safety glass like the lowers. Please let me know. Thanks for all the info as well.
11-15-2009, 02:43 PM
#83
1973 23' Safari
1977 23' Safari
2018 25' Flying Cloud
Palmer Lake
Sorry, they've all already gone to other members. Maybe someone else will have a spare. Good luck.
Zep
12-13-2009, 04:51 PM
#84
1976 29' Ambassador
Wichita
, Kansas
Have been following this post with great interest. Had to comment, NEVER EVER use petroleum jelly on rubber or vinyl. I would simply try some KY jelly. As you slide the newly completed glass assembly back into the frame, simply spray the gasket with a fine mist of water to reactivate the KY and you should be home free..
Mike
12-13-2009, 06:07 PM
#85
1973 23' Safari
1977 23' Safari
Palmer Lake
Originally Posted by Joebanjo
...NEVER EVER use petroleum jelly on rubber or vinyl. I would simply try some KY jelly. As you slide the newly completed glass assembly back into the frame, simply spray the gasket with a fine mist of water to reactivate the KY and you should be home free..
Thanks, Mike. I have always been slightly uncomfortable with peetroleum jelly on rubber, but didn't know if that was rumor or fact.
Zep
12-13-2009, 07:17 PM
#86
Corona
Mike
"Silicone spray" works great on rubber and vinyl.
12-13-2009, 07:23 PM
#87
Ottawa
, ON
Richard,
In my search for the correct butyl and gaskets, I found this page at DK Hardware. You could get the exact thickness butyl tape to repair your vista view.
Architectural Butyl Tapes
Zep
Zep,
They seem to have shuffled things around on that site since you quoted it in 2007. Here is the page for the tapes, but what size were you saying is the "perfect" one for Vist View windows?
http://www.dkhardware.com/search.asp...=Architectural Butyl Tapes
Edit: whoops, I should have read more or the thread, you found many other things out after that post back on the first page of the thread. Like that the 0.15" pre-shimmed butyl tape is the size. Just ignore this post, I'll ask again when I finish reading the whole thing.
“Courage is being scared to death, but saddling up anyway.” ...John Wayne...........................
12-14-2009, 06:52 PM
#88
1976 29' Ambassador
Wichita
, Kansas
Andy's idea is the best. Silicone spray would be the way to go. The reason I know that petroleum jelly is a no no on rubber is remembering what it does to swimming pool equipment ( O rings and seals). The petroleum based jelly tends to make rubber swell and deteriorate over a very brief time.
12-14-2009, 07:08 PM
#89
1976 29' Ambassador
Wichita
, Kansas
Now , I'm gonna ask a very silly question. I, like all of you are facing the same window film issues that you are. Some of my windows are fogged and they are the double pane configuration. Why then, is everyone wanting to jump back into the double pane window configuration when Airstream themselves have abandon the notion of double pane windows for their trailers? They must have found the whole concept too troublesome to continue. Can a double pane window really provide that added energy bonus to an all aluminum trailer? One reason they make cookware out of aluminum is the fact that the metal transfers thermal energy almost as well as copper. I've never owned an Airstream in my life until 2 months ago when I bought this 1976 model. But even the best Airstream would bleed heat in the winter despite the windows, would it not???
At any rate, I'm looking at trying to convert my double pane windows and frames to single pane use.
Now.....treat me gently, I'm new to all this, Right Andy?
Mike
12-14-2009, 07:24 PM
#90
Ottawa
, ON
Mike
Saaaaay... Fer a new kid, yer pretty smart there, Joe! Well, or so it seems to me.
I mean, after I read that whole story, I had two thoughts:
1. I could never do that, no way, not good enough with my hands or feet
2. It's tooo much blame work anyways!
Now, that's not to say that I don't admire all your guys who have done it, and especially you, Zep, for documenting it so well, but I'm just stating that it's not within my talents to do that kind of "high-level" type work.
So, I'm wondering too, why not just go to one pane? Less pain, n'est-ce pas?
12-15-2009, 08:17 AM
#91
1973 23' Safari
1977 23' Safari
Palmer Lake
... Why then, is everyone wanting to jump back into the double pane window configuration when Airstream themselves have abandon the notion of double pane windows for their trailers? They must have found the whole concept too troublesome to continue. Can a double pane window really provide that added energy bonus to an all aluminum trailer?...
A year ago I had the Sovereign up in Seattle for their unprecedented cold December. Average temperature was about 20 degrees for three weeks. If you've seen my thread on the Sovereign, you'll recall that it has a catalytic heater. All but one of windows were double pane.
The one single pane window collected all the moisture as a thick layer of ice. The double pane windows remained free of condensation. I was very surprised at the stark difference in performance.
It's easy to add BTUs to warm up. It's much harder to subtract them. I'm more interested in comfortable sleeping in hot deserts (Burning Man, etc.). I don't think the double pane window performance is as helpful in hot weather, since a lot of my desert time is boondocking, so the windows are open. But anything that will allow a 13.5K BTU air conditioner to keep up when I've got a hookup in Vegas is OK with me.
Yes, they are a lot of work, but when you break your first inner glass, let me know how much work it is to clean out the shards and then devise some way to properly restrain the outer glass in the thick frame. I'm betting it's almost as much work, maybe more. I'm just saying that converting to single pane may not be "easy." I did it for the one window that I broke accidentally and it was a PITA.
Zep
12-16-2009, 04:31 PM
#92
1976 29' Ambassador
Wichita
, Kansas
Zep, I must admit, you have a good point! Anything that will help that air conditioner
keep up with the hot sun in Las Vegas would be time well spent. I probably won't encounter the temperatures you spoke of here in Kansas. But we do get cold!! The thing that bothers me is the spector of having to deal with the condensation that will likely occur again. Maybe install some kind of small weep hole tube to allow dry air to enter and moist air to escape, some kind of vapor exchange. Something you could attach a small aquarium pump to in the event of moisture between the panes to allow them to dry.....just a thought.
At any rate ..I stand corrected.
I want to explore rebuilding the window as a single pane unit from the ground up. The breaking the inner glass idea may work, but I want to avoid the mess too. Also that 34 year old seal is brittle. I'm looking at removing the panes, keeping the outer (larger of the two) installing a filler in the double pane channel, buying a new single pane "U" gasket and reassembling the window as a single pane. I have found the "U" gasket, and living here in Wichita, I have access to some pretty neat materials as surplus aircraft stores in town have a wealth of materials at my disposal for the forming of a suitable filler.
Lastly, all of you on the forum are a wealth of information.
Many Thanks..
Mike
12-16-2009, 08:45 PM
#93
1973 23' Safari
1977 23' Safari
Palmer Lake
...The thing that bothers me is the spector of having to deal with the condensation that will likely occur again. Maybe install some kind of small weep hole tube to allow dry air to enter and moist air to escape, some kind of vapor exchange. ...
Mike, there are weep holes in the frame, but they are for draining any water that collects in the "U" of the frame, under the seal. They aren't intended to drain the space between the panes. I think you will find that being able to vent the space between the panes will only result in trapped water, or lots of condensation on the glass. You'll never get it out unless you actually have an active ventillation ability, and that would have to be "off" in order to get any performance out of the window. I've found that my rebuild of the windows has been successful, in that I don't have any condensation between the windows.
... I'm looking at removing the panes, keeping the outer (larger of the two) installing a filler in the double pane channel, buying a new single pane "U" gasket and reassembling the window as a single pane...
Good luck. My kludged together single pane window has done OK.
If I might be so bold, if you do as you plan, if you have an inner pane left over, I'd sure like to have it. I could make that single pane window back into a double. The down side is, they are HEAVY!
Zep
12-17-2009, 04:18 PM
#94
1976 29' Ambassador
Wichita
, Kansas
Hey Zep
I have the small weep holes in the frames and understand their function. I heard Andy in another thread talk of carefully drilling some holes and inserting a small wire through the butyl rubber to provide for a means of draining and I presume drying moisture caught between two panes of tempered glass. The space between the panes is nothing more than a "dead air" insulator is it not? I thought a preemptive solution to moisture between the panes might be a pre- positioned tube to allow draining and possibly drying a condensation problem one might have in the future. The tube could be sealed when not in use , thereby preserving the "dead air" insulation effect of the additional pane. Your double pane fix is very impressive by the photos ,and after speaking to you , I am re-evaluating my plans. You are persuasive!!
As far as those extra panes go, if I have some left over to sell, (assuming I proceed with my conversion) you will be the first guy I let know. ;-)
Thanks Zep
Mike
12-17-2009, 09:12 PM
#95
1973 23' Safari
1977 23' Safari
Palmer Lake
As far as draining the inner space between the panes, I don't know how big a problem surface tension and capillary action will be. I'm betting that because the holes will be very small, the problems will be big.
Now, if you were forcing some air in at the same time, you might have a lot of success.
Zep
12-18-2009, 06:29 AM
#96
Guntersville
, Alabama
What about the bugs and dust?
It seems if there is a "weep hole" to let moisture out, dust and spiders will surely find a way in. Then the question becomes "how do you clean between the panes?" Good luck to all!
12-18-2009, 06:01 PM
#97
1976 29' Ambassador
Wichita
, Kansas
Well, the bugs and dust would be a problem if you left the drain vent open open all the time. Zep does have a point about the hole would be very small. Possibly too small to be of any real value, especially if it were in the form of a small tube. Oh well, it was an honest idea anyway!
Now where did I put that butyl rubber, and that extra pane of glass???
Mike
04-09-2010, 09:26 PM
#98
Peasleeville
, New York
I realize this post is not active, but just wondering if anyone has tried the low e films by 3M as an interior window film? This looks like a great product, and it might even come in a security film, which could be useful if an accident were to occure and you can not do an immediate repair.
04-09-2010, 09:27 PM
#99
Peasleeville
, New York
03-18-2011, 01:20 AM
#100
Stubborn but learning
1973 31' Excella 500
washougal
