Old 11-05-2007, 07:51 AM   #1
Zeppelinium's Avatar
1973 23' Safari
1977 23' Safari
2018 25' Flying Cloud
Palmer Lake , Colorado
Repairing double pane window solar film
After seeing other threads on this subject, and after a year of trepidation, I'm going to try to get through this from start to finish, with photos.
THE PROBLEM: Afte a zillion years, the solar film applied to the inner side of the outer pane of glass starts to craze and bubble. Here's a detail how mine have bubbled in the silvered area. The rest of the film looks like it has long wrinkles.
Name:	IMG_7371 bubbles-s.jpg
All mine are in bad shape, but from what I can tell, the film was two-tone, with a silver component along the top edge. You can see the effect of this along the left edge (the top edge of the window when installed) in the photo here.
Name:	IMG_7369 window-s.jpg
On inspection of the frame, you can see 4 rivets holding the frame together and a row of about 8 rivets holding the hinge piece at the top edge. All of these must be drilled out (well, you could drill out only the 4-5 at one end of the hinge piece and that would allow the two sides of the frame to come apart, up to you). The rivets have very small heads, which lead me to believe they were 3/32, but in fact they are 1/8 and soft. It is easier to drill the hinge rivets out from the back side, which requires removing the weather striping in that area. I was amazed at the strength of the glue and rubber after 30 years. It was compressed, but not cracked at all.
Name:	IMG_7372 removing weather seal-s.jpg
Once you get the rivets out, you can slide the frame off with a mallet and wood block. I made this a little easier by using the wood block and mallet to spread the frame from the top and bottom edges a little, before tapping on the end to slide each piece off. Note the slim square cross section steel bar sticking out of the frame to the right of the mallet handle. Two of these are what holds the frame together and prevents the top and bottom edges from bowing out away from the glass edge.
Name:	IMG_7373 removing frame-s.jpg
Once you get the frame pieces off, you can remove the U-shaped rubber gasket that runs in one piece around the glass. What you find are the two pieces of glass "glued" together with something resembling the butyl "plumber's putty" that's widely used to install sinks today. There is also a silver metalic tape that overlaps the glass by about 1/8" on both sides. Presumably, this kept the putty from sticking to the rubber gasket, or maybe was just a feature to keep workers' hands from getting all gooked up. Anyway, you have to cut this all the way around, as it still can apply a lot of tension between the two sheets of glass.
Name:	IMG_7374 foil edge-s.jpg
NOW FOR THE STUPID PART! Don't use a common screwdriver in a twisting motion to get the two sheets of glass apart. CRACK, SHATTER! I was about 90% done and broke the inner glass (all the while thinking, jees, this is stupid). I'll fix it with lexan, no problem, but still totally stupid. I recommend (first) go slower and have some patience and (second) use a few slim wood wedges or something equally soft.
The film comes off pretty quickly. If you use a scraper, be sure to use steel, not carbide, which will surely scratch the glass. The silvered area came off immediately, but the non-silvered part of the film required some water to get the glue off. (the glue for these solar films is water soluble, but you have to scratch off the film in order to get the water on the glue)
Name:	IMG_7376 scraping film-s.jpg
Next step is to order the U-shaped gasket material, get the replacement piece of lexan, and find out what the putty is between the two sheets. I know I've seen the gasket material mentioned on another thread on this same topic, but I don't have a clue about the putty. I'm debating reinstalling a new sheet of solar film. Anyone have thoughts on this?
For info, the double glass panel was made up of 0.152" outer glass, 0.2" putty, and 0.122" inner glass. The solar film thickness is negligable. Total time to this point (including sweeping up the broken glass), 1.5 hours.
Zep
Zep@Charmedquark.net
Old 11-05-2007, 07:54 AM   #2
Remember, Safety Third
Jim & Susan's Avatar
Catfish Corners , Georgia
I feel a great thread in the making.......
Solve for X, Or is it Y?
www.nesa.org
Air No. 6427
Old 11-05-2007, 08:00 AM   #3
Zep
Been there, done that! Great advice. The "putty" looking stuff is probably butyl. I got a 30' x 3/4 x 1/8 roll for about $6 at the local airstream dealer for my front wing window work.
www.nesa.org
Air No. 6427
Old 11-05-2007, 10:06 AM   #4
Blu_Hwy_Lady's Avatar
1972 23' Safari
Placitas , New Mexico
Thumbs up Wow! Way to go Zep!
What a carefully documented process. Karma comin' at you. Thanks for sharing. The worst thing about my AS is the windows. I'd heard about breaking out the inner pane to scrape the crud off and then just having single pane. Seeing your process convinces me that I think I'll just have to live with the crappy windows. You're a brave man to take on such challenge. Still, I'm book marking your thread for "someday."
Airylle 1972 Safari featured for 5 nanoseconds in the movie Wild Hogs
Blu_Hwy_Lady is offline   Reply With Quote
Old 11-05-2007, 10:06 AM   #5
Ganglin's Avatar
1971 27' Overlander
Central , Ohio
Images: 13
Zep,
Are you going to tackle a vista view also....
Old 11-05-2007, 10:46 AM   #6
1973 23' Safari
1977 23' Safari
Originally Posted by Ganglin
... Are you going to tackle a vista view also....
Not a chance!
The Vista View windows come in two types--early 70's had a flat retaining "ring/clip" that you could pull out, which released the inside pane (which was plexiglass). Taking that clip out could be done with the window installed in the shell. The frame is welded and the clip is the only access. I did one back in 1998 using plumber's putty (which is all I knew about back in those days) and it didn't hold up very long--blobs of putty sliding down in the window in the heat of the Mojave sun. But I did manage to get the solar film cleaned up.
The later Vista Views (maybe 1975 and on) have two frame halves riveted together, just like the larger windows. But this means that to get them apart you have to remove the whole frame/window from the shell. PITA for sure.
If you're not familiar, my solution (in another thread) was to completely remove all vista view windows and patch them over with 2024-T3. I've got two of the later versions and one of the earlier out in the shop, I just noticed.
The bottom line is, however, I'm not fooling around with Vista Views. I don't need badly insulated and leaky ports in my shell--which is a mild version of what I really think.
Zep
Old 11-05-2007, 11:08 AM   #7
flint , Michigan
I'm in the same boat with my '74 Vistaviews with plexiglass. I am looking for something to replace the putty that was there originally. What would you use today, instead of the plumbers putty?
I love this forum. An endless wealth of information, some of it timely too. I wish it had been available 12 years ago when I was living in My Baby.
flashbackk is offline   Reply With Quote
Old 11-05-2007, 11:18 AM   #8
On my '73, that putty stuff in the Vista Views is also butyl. Of course, I didn't figure that out until after I rebuilt them. Just by dumb luck that I found a fellow in window shop that gave me the right stuff.
www.nesa.org
Air No. 6427
Old 11-05-2007, 11:45 AM   #9
Ganglin's Avatar
1971 27' Overlander
Central , Ohio
Images: 13
Zep,
The vista views in my 71 are just a single pane glass - no film and no interior plexiglass or any channel for it to fit in. You begin to wonder how many ways they actually tried to make them. May sound nutty but, since we've not had any problems with ours, I was actually considering getting another one and putting it in the can over the tub....
Keep the photos coming man... good stuff.
Old 11-05-2007, 03:36 PM   #10
1973 23' Safari
1977 23' Safari
Actually, I'm betting you had the model with the clip and a PO removed the inside plexiglass. That was the one big advantage of that design. You could easily convert it to a single pane and everything would look unmodified.
Zep
Old 11-09-2007, 12:33 PM   #11
1976 31' Sovereign
1963 16' Bambi
1971 21' Globetrotter
Marbletown , New York
Wow! Zep you are amaizing! You have built my confidence better than a therapist.
Did you find the gray U shaped gasket material? My windows have some white rubbrt plugs loose on the inside bottom of the windows (looks like they fell out of something/somewhere) and that they plugged some holes. Is it possible that they were something to do with draining condinsation. Do you have any ideas? Do you think that you will use a butyl calk? Is this something that can be had at a glass shop?
Once again for the comprehensive info.
Stone Ridge is offline   Reply With Quote
Old 11-09-2007, 01:01 PM   #12
azflycaster's Avatar
2002 25' Safari
Dewey , Arizona
Images: 62
My 75 TW vista views look like crap. My inner window is Plexiglas and it has the retainer ring holding it in. The split in the ring is at the 12 o'clock position. How do you remove the ring? It seems to be pretty snug.
Richard
Old 11-09-2007, 01:09 PM   #13
1973 23' Safari
1977 23' Safari
Richard, that clip comes out with effort. There is no good way to grip it, so you'll wind up dinging it a little. I used a sharp edged screwdriver and mallet and I place the screwdriver point next to the split and tapped toward the center of the pane, catching the clip with the sharp edge and forcing it to slipe along the surface of the plexiglass.
Stone Ridge, yes, I'll use butyl. I'm working on determining whether 0.25" thick will make the total panel too thick (by about 0.03"). The alternative is to use what the glass folks call pre-shimmed butyl, which has a rubber cord in it. There is version that is 0.215" thick, which would make a panel about 0.01" undersized.
The "plugs" you see are a method of providing that pre-shimming action to maintain a consistent butyl thickness as you press the glass panes together.
The gray U-shaped gasket material is available, but I need to find a shop who will sell one roll of it, rather than the minium order of 8 rolls from the wholesaler. More news on this next week.
Zep
Old 11-10-2007, 11:11 AM   #14
1973 23' Safari
1977 23' Safari
Richard,
In my search for the correct butyl and gaskets, I found this page at DK Hardware. You could get the exact thickness butyl tape to repair your vista view.
Architectural Butyl Tapes
Zep
Old 11-10-2007, 11:30 AM   #15
2002 25' Safari
Dewey , Arizona
Images: 62
Thanks Roger, but 32 rolls of 25 feet seems a bit much for 2 Vista View windows
BTW, Are you planning a trip to Dead Horse this year? I bet there are still some undiscovered trailers on the side of the road for you to find...
Richard
Old 11-10-2007, 11:58 AM   #16
1973 23' Safari
1977 23' Safari
damn damn damn edit timed out....
OK, here's the deal. I can't find the butyl tape in less than 32 roll quanity order. The part numbers are
Butyl 0.215" pre-shimmed tape -- 7241YP1, 20 ft roll, $10.45 times 32 rolls = $334.40
Vinyl Gasket for 1/2" window assembly -- WV3866, 100 ft roll, $26.89
To match up the length of the butyl to the length of the gasket, you'd need 6+ rolls of gasket. That's enough to do 60 windows. The materials would run $500, or a little less than $10 per window. Surely we have enough forum member interest to cover that many windows. Just for my Sovereign and Safari I need to do 8 windows.
Do we have any community interest?
If anyone has found the butyl in single roll quantities, please post a note here. Thanks.
Zep
Old 11-10-2007, 02:06 PM   #17
1973 23' Safari
1977 23' Safari
Oops. went down and checked the Airstream window frame dimenions. It's not 5/8" like I thought, but only 9/16". It may seem like a small difference, but it means that the 0.15" pre-shimmed butyl tape is the right material, not the 0.215".
Zep
Old 11-14-2007, 05:28 AM   #18
Lumatic's Avatar
1993 34' Excella
Estancia , New Mexico
Images: 16
Butyl and film stuff
I would be interested in going in on some butyl if it would work on my wings (see my wing window thread started 11/13).
BTW I saw this film at a paint store called Solar Stat 800 783-0454. Brochure says "It's so easy to install you'll be an expert in no time at all". 24"x15' $35, 24'x100' $120
Anybody have a source for metallic window film?
Old 11-14-2007, 09:39 AM   #19
1973 23' Safari
1977 23' Safari
there's another thread somewhere that debates the type of film and what effect it would have on your ability to see out at night. Darker film (or maybe the silvered stuff) evidently is better at rejecting heat, but darker to look through. I'd like anyone's thoughts on this. I think I also saw a comment that some types of film act like one-way mirrors--can't see in from outside, but at night with the lights on inside, the outsiders can see in fine. Seems a little backwards but it must be physics.
The Sovereign windows that I'm doing were silvered along about the top 1/3 of the window. I have seen other late 70s models that have solar film, but were not silvered. I don't know if it was due to different year of the trailers or what. Maybe this was a well understood tradeoff back then and we've lost the knowledge...
Zep
Old 11-14-2007, 09:52 AM   #20
1973 23' Safari
1977 23' Safari
Weep Holes
There are weep holes along the bottom edge of the double pane windows. It wasn't obvious how these worked until I looked carefully at the cross section of the frames yesterday. I thought perhaps they vented the space between the glass, which is counter productive for double pane windows, so I've been curious for some time.
Some of mine were clogged with a white powder, which comes out easily with a small drill bit and finger power.
Here's the left half frame from the window in the first post. The single rivet hole is to secure the bar that both keeps the frame together and the edge straight.
Name:	IMG_7381 holes labeled-s.jpg
You can see from the drill bit angle that the hole is drilled at a steep angle through the small lip in the frame and up into the drain channel. There's a continous opening in the extrusion from the glass channel to the drain channel, ensuring that any water that gets into the frame can drain to the bottom and then outside, without creating pressure to leak through the frame to inside (given that you keep your drain holes clear).
Name:	IMG_7383 drill bit-s.jpg
ID:	49340Click image for larger version
Name:	IMG_7384 channel detail-s.jpg
BTW, I've found sources for the butyl and gasket. Should be here next week. More then,
Zep
Rear window reflective film jaiman Windows & Screens 4 04-06-2018 02:10 PM
window film needs replacing flyingscot Upholstery, Blinds, Walls & Interior Finishes 5 05-14-2007 03:26 PM
double glazed window film inside? Yikes! ray henton 1974 - 1979 Safari 2 07-05-2006 05:39 PM
Repairing Front window '63 Safari srgntpepper Windows & Screens 10 08-29-2003 08:27 PM
bad tint film in double pane window wcdelorme Windows & Screens 11 05-16-2003 01:53 PM
