Old 10-08-2007, 06:25 PM   #1
chapparel's Avatar
1965 22' Safari
Three Rivers , California
Removing Windows
Hi All,
I would like some ideas from you all about how to remove windows and frames from one Airstream to another. Some of them are the same size, so do I drill our the rivits from each window or what?
I really think this is possible as how do you replace a window that breaks. I would welcome any suggestions. Thanks.
chapparel is offline   Reply With Quote
Old 10-08-2007, 07:24 PM   #2
Originally Posted by chapparel
Hi All,
How you replace a window, depends on what window, and what year trailer. Does the window open? Is it a fixed window? Stack window? Vista view window? Wrap window? Wing window?
Changing window from one year to another depends on what years are the trailers?
Old 10-09-2007, 09:30 AM   #3
chapparel's Avatar
1965 22' Safari
Hi Andy, Most of these windows open. One is a Stacked Window ( meaning that upper window opens and the lower one does not) or vise versa. No Vista View windows. No Wrap windows, and no Wing windows .
Windows are being supplied from 67' Ambassador and the recepient is a 65'
Safaril. No, I will not being selling anything else from Ambassador until I change all items needed for the Shasta. Then I will probably list the Ambassador as is or will use it for Storage. Thanks.
Martha
Old 12-17-2007, 11:35 AM   #4
1981 27' Excella II
cypress , Texas
I have just bought an 81 Airstream Exella II. It needs a new front window. Is there an exploded view of this area so I can determine what parts, brackets, gaskets I will need to repair ?
The exploded view would help alot !!
Steve
steve furbus is offline   Reply With Quote
Old 12-17-2007, 11:39 AM   #5
Zeppelinium's Avatar
1975 31' Sovereign
1977 23' Safari
Palmer Lake , Colorado
...Windows are being supplied from 67' Ambassador and the recepient is a 65' Safaril...
I think this is a big problem. Aren't the 67 windows the curved Corning glass and the 65 windows are square with a frame on the glass? These are completely different in dimension and the nature of the shell-mounted frame.
Zep
Old 12-17-2007, 11:52 AM   #6
Martha
You cannot easily use 67 windows in a 65 trailer.
The 67 window frames are within the shell. You would have to loosen a considerable part of the window sheet metal to get the window frame within the shell.
Next problem would be how your going to hide the marks on the sheet metal that the 65 windows have caused.
But, to each his own.
Old 12-22-2007, 05:17 PM   #7
1967 17' Caravel
Ridgecrest , California
Is there a how-to on changing windows, preferable in a 1967 Caravell? I have a broken window for which I got a replacement from Andy. BUT, I'm stumped at how to change it.
Justang is offline   Reply With Quote
Old 12-22-2007, 05:40 PM   #8
Instructions come with the windows.
If for any reason you did not receive it, please provide via a PM, an e-mail address or fax number and we will get it to you Monday, or sooner, if I get to the office earlier.
Briefly, the hinge comes apart from the inside. You should see several screws on the inside of the hinge. Removing those screws, releases the inside of the hinge.
Old 12-24-2007, 09:17 AM   #9
Instructions were sent to you along with a drill bit, in a plastic 3" x 5" package, in May 2007, along with a gasket, a tube of adhesive and your new window.
Please call us if you cannot find the plastic envelope.
Removing small windows--no margin Zeppelinium Windows & Screens 7 07-16-2007 05:03 PM
removing floor without removing shell nevisstudio Repairing/Replacing Floor &/or Frame 11 07-24-2005 10:47 PM
removing a picture happier Forum Admin, News and Member Account Info 7 02-22-2005 10:16 AM
Windows-probs, Linux more prbs...back to Windows Kistler Off Topic Forum 13 11-04-2004 09:19 AM
removing inner window on curved front windows remcolent Windows & Screens 1 04-12-2004 03:55 PM
