Old 09-05-2007, 08:11 AM   #1
Lumatic's Avatar
1993 34' Excella
Estancia , New Mexico
Images: 16
removing window frames
I need advice on removing window frames, in this case wing windows. I have read cut off the rivets with a chisel. As an alternative should I drill the rivets out?
Old 09-05-2007, 10:27 AM   #2
Got gandkids?
Jim & Susan's Avatar
'Possum Holler , Georgia
If yours are like mine, take a look at what I've done: http://www.airforums.com/forums/432118-post433.html I need to update this tonight with more info. Maybe that can help a little.
www.nesa.org
Air No. 6427
Old 09-05-2007, 07:48 PM   #3
Lumatic's Avatar
1993 34' Excella
Images: 16
PS
I am specifically interested in the wing windows. Both of mone inexplicably broke. I have a friend who will let me take off a couple from a parts coach which would mean taking out 2 sets of windows and installing one. I wonder if there is a way to slide in a piece of Lexan by only taking out the vertical frame piece towards the center without pulling the whole frame. But if I need to take out the frames what is the best and/or easiest way to get them out.
Old 09-20-2007, 03:33 PM   #4
Me loves da little twinky
Rivka's Avatar
1971 18' Caravel
1974 29' Ambassador
1966 26' Overlander
Portlandish , State of Flux
Send a message via AIM to Rivka
oo side question, good luck btw.
if your friend has a parts coach and you are taking the glass, might i be able to chat with them about the inner plastic frame for those same side windows, strangely by 71 caravel came to me with those removed and i have been keeping my ear to the ground for a year about a replacement source. My glass is fine and this would sure make good use of those windows of hers!!
Rivka is offline   Reply With Quote
Old 09-20-2007, 06:30 PM   #5
Lumatic's Avatar
1993 34' Excella
Images: 16
Interchangeable parts?
The parts coach I referred to above is a 75 (I think). The 71 wing is single pane. The 75 is double pane. From what I have been able to find out 69 is the only wing window that is not interchangeable. I'm hoping to just pop the 71 out and the 75 in. Could it be that easy? I'm still looking for advice on how to get the little boogers out without breaking them.
I don't know if the 75 interior trim will fit your 71, but I will compare, when I can. It might not be anytime real soon as the parts coach is a wee bit of a drive. BTW I need the inside galley window trim or to repair mine so I can hang the rolling blind.
need help with window frames whistler Windows & Screens 7 06-09-2014 12:13 PM
Painting Window Frames Bfrank Windows & Screens 1 06-25-2007 11:23 AM
Removing window frames..'68 Overlander???? fly2havefun Windows & Screens 3 05-18-2004 07:14 PM
Aluminum window frames mcostanzo Windows & Screens 0 04-16-2003 04:42 PM
MH side window frames Bfrank General Motorhome Topics 6 04-15-2003 12:15 PM
