Removing Vista View window on '68 Overlander
Could someone please give detailed instructions on how to remove the vista view frame on a 68 Overlander? This window is located to the right of the door, just above another window. It is 17" wide and about 7" tall. The pane itself is, or was curved (it has been broken out) but the corners are square, not rounded. We have removed the rivets from around the frame, both on the inside and outside of the trailer but so far have only been able to remove the bottom of the window frame. The rest won't budge. Does the frame come out in four pieces? How much vulcom is holding this thing in? How far to the left/right do the sides of the frame extend?
