Old 05-30-2010, 01:36 PM   #1
maxandgeorgia's Avatar
1995 30' Limited
Ashland , Missouri
Removing 'pebbling' on '78 Argosy windows?
I thank you for your patience and information, in advance. I've skimmed thread topics in the search function, but have not found what I'm needing. Some of the windows (plexiglas?) in our '78 Argosy have a clouding or pebbly effect which I remember reading about once upon a time, where someone recommended how to remove much of this in order to have a clearer window. If someone knows what solution will help remove this, thanks for sharing the information so we can really enjoy the bright open interior of our new cutie. ~G
maxandgeorgia
1995 Airstream Classic Limited 30' ~ Gypsy
1978 Argosy Minuet, 6.0~Minnie/GPZWGN
Chev Silverado 2500HD Duramax/Allison, 4X4, Crew Cab
WBCCI #5013 AIR #2908
WDCU
Go, Mizzou...Tigers on the prowl!
maxandgeorgia is offline   Reply With Quote
Old 05-30-2010, 08:26 PM   #2
Moderator Emeritus
overlander64's Avatar
1964 26' Overlander
1978 Argosy Minuet 6.0 Metre
Anna , Illinois
Images: 183
Removing "pebbling" on '78 Argosy windows?
Greetings Georgia!
The acrylic windows respond well to being treated like aircraft acrylic windows. The polishing and maintenance products will do wonders for the acrylic windows in our Minuets. I have sourced the products that I use on my Minuet from Aircraft Spruce. Among the products that I have used with good results are:The 210 Plus Plastic Scratch Remover lessened the impact of fine scratches and pits considerably on my Minuet. Clarity and overall appearance was greatly impoved with the NOUS 3 step process. These products are also wonderful for cleaning and polishing the rockguards on the front windows.
The one thing to remember with these acrylic windows is to avoid amonia-based window cleaners as they can increase the hazy appearance rather quickly.
Good luck with your Minuet - - I am certain that you will enjoy your Minuet travels!
Kevin
Kevin D. Allen
AIR #827
Old 05-31-2010, 05:55 AM   #3
wheel interested's Avatar
2007 23' International CCD
Lapeer , Michigan
Hi Kevin, we have some scratches on the window protectors from the PO meeting up with some tree branches or leaves. Can you recommend one product or do these each need the other companion products and tell us how you achieve good results? I am concerned about putting more scratches in or making it more apparent than it is now. Thanks.
Caroljb
photography
wheel interested is offline   Reply With Quote
Old 05-31-2010, 09:21 AM   #4
1995 30' Limited
Ashland , Missouri
Kevin, once again you come to our rescue! I am constantly amazed at the fund of information you share with this forum. I knew there was a specialized cleaner solution to use to avoid additional damage, but I could not find it in my searches, and Bingo! You have the specific product we need to fix our pebbly windows, or at least improve them. Thank you, as always! ~G
maxandgeorgia
WDCU
Old 06-01-2010, 08:23 AM   #5
Moderator Emeritus
1964 26' Overlander
Anna , Illinois
Images: 183
Greetings Carol!
The NOVUS products are kind of like the aluminum polishing products - - you work from the most abrasive to the least abrasive. I have, however, learned that there is nothing wrong with experimenting with the least abrasive to see if it will resolve the problem. I usually use micro-fiber towels to apply the polish (depending upon temperature, a slightly damp application towel will help to keep the polish from drying too quickly).
Aircraft Spruce also offers a solvent-based scratch repair, but I haven't tried it. My concern has been that it would change the color of the tinted rock guards.
Good luck with your project!
Kevin
Kevin D. Allen
AIR #827
Removing Screen From Windows mcplaidpiper Classic Motorhomes 1 07-05-2008 07:20 AM
Removing Windows chapparel Windows & Screens 8 12-24-2007 09:17 AM
Removing small windows--no margin Zeppelinium Windows & Screens 7 07-16-2007 05:03 PM
Pictures of Removing a Curved Argosy Window Chopper Windows & Screens 6 09-22-2006 09:42 AM
removing inner window on curved front windows remcolent Windows & Screens 1 04-12-2004 03:55 PM
