Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Windows, Doors, Locks & Vents > Windows & Screens
Old 05-14-2011, 04:37 PM   #1
1972 31' Sovereign
Valdosta , Georgia
Removing inner window pane
I know I had read a posting on how to remove the inner pane of windows. I have a 72 AS and have the plexiglass interior panes that I need to remove due to the film coming off. Can anyone point me in the right direction to the correct thread?
thanks
GaCamper is offline   Reply With Quote
Old 05-14-2011, 04:42 PM   #2
x
XXXX , XXXX
Which window are you talking about? The upper elongated ovals are called Vista View Windows, then ther are the regular opening lift up windows and the other lower elongated oval windows are called stack windows.
wasagachris is offline   Reply With Quote
Old 05-14-2011, 08:25 PM   #3
1972 31' Sovereign
Valdosta , Georgia
windows
Actually, I am talking about all three types of windows. All of mine are fogged or the film is pealing.
Old 05-14-2011, 09:07 PM   #4
x
XXXX , XXXX
Ga well if your stack & VV windows have plexi inner panes there should be an aluminium split retaining ring around the perimeter of the inner pane. If you carefully pry up the ring at the split you will be able to pull the ends of the split towards each other and the ring will come free of the window. The you need some type of hook tool to get under the plexi inner pane and work it free from the butyl tape holding the inner pane to the outer. Once it comes free you can then clean off the old butyl tape and the deteriorating tinting. Retint, apply new butyl and reverse the process for reassembly. Look here for how I did mine. http://www.airforums.com/forums/f454...tml#post864410
Actually read the whole thread it is very informative and started bt a fantastically talented guy.
So now for the rest of the lift up windows. If the inner panes of them are plexi they are very easy to remove and fix. If you look all around the inner edge of the window frame, not the window sash but the frame that holds the glass you should see several screws. The hold the inner plexi pane in its own frame. Once the screws are removed you can gently pry the inner frame and pane free from the outer pane and frame. Then clean off the tint, reapply and use a new closed cell gasket to seal the two pane frames together. You will have to remove the window frames assembly from the sash. This is done by first removing the lift up handles, then remove the screens and screen frames which are screwed into the window sash. Once the screens are removed , remove the lift up rods from the window sash. Then from outside manually lift the window up almost 180 degrees and the window frame will drop free from the window sash. Both the window frame and the window sash have a corresponding J hinge connecting them together. Be carefull reinstalling them so as not to bend either hinge. Usually this requires two people to reinstall them. One person holds the window frame in place and the other person from inside gently taps the middle of the window hinge into place. They tend to bow out in the middle and won't easily mate together.
Old 05-15-2011, 06:06 PM   #5
1972 31' Sovereign
Valdosta , Georgia
Windows
Great, thank you for the information. Sounds like a good weekend project.
AS280 - Front (driver) sliding window latch dalefox Classic Motorhomes 16 01-14-2022 01:42 AM
'58 Hehr Window - Is this the correct window operator replacement? mello mike Windows & Screens 22 10-08-2012 08:49 AM
Rear window leak fixed! Really? I think so. 1964 GlobeTrottin 1960 - 1964 Globetrotter 0 04-30-2011 05:42 AM
Replace missing front window with jalousie? Cruisette Windows & Screens 6 03-31-2011 04:23 PM
Got my window out. Now what? Breadbug Windows & Screens 3 01-23-2011 07:27 PM
