Old 07-03-2014, 12:51 PM   #1
Removing HEAVY oxidation from Jalousie Windows
I took apart one window. Setup my bench grinder with a buffing wheel and some Rouge and got to work. I realize now this will take AGES and there may be parts I can't get to. Additionally, I have spots of crud that take awhile to buff off.
Question. Is there some Safe trick for getting the majority of aluminum oxidation off Jalousie windows? Some wash? Chemical? Oil?
The only interesting this I saw on the InterWebs was this guy rubbing Marvel Mystery Oil on Aluminum motorcycle parts a day or two before to soak off a majority of crud. I like that idea.
Just want to make sure I'm not missing anything.
Thanks!
Pics of my progress attached.
ID:	215555   Click image for larger version
bass-o-matic is offline   Reply With Quote
Old 07-03-2014, 03:31 PM   #2
truckasaurus's Avatar
1960 33' Custom
Saskatoon , Saskatchewan
I'm not familiar with any Jalousie window like the one you have but if it's not too thin maybe a bead blaster or soda blaster would help? I know after the windows on my '61 project I'll be going for some blasting solution rather than endless half baked grinding solutions.
truckasaurus is offline   Reply With Quote
Heavy Oxidation monocoque Cleaning, Stripping & Polishing 179 03-08-2016 07:33 AM
removing jalousie windows jrossingaul Windows & Screens 1 03-09-2013 05:33 AM
GOJO! First cut for heavy oxidation muddy_hollow Cleaning, Stripping & Polishing 11 06-22-2010 01:52 AM
Does oxidation cause oxidation bmklawt Ribs, Skins & Rivets 9 02-09-2009 09:21 AM
Heavy Oxidation #2 cuyeda Cleaning, Stripping & Polishing 10 06-11-2008 04:31 PM
